Page 22 of 51 FirstFirst ... 12171819202122232425262732 ... LastLast
Results 316 to 330 of 761
  1. #316
    Quote Originally Posted by asliyucegsm View Post
    link.CarProg v 4.74 Repair - YouTubeI did it with SEGGER worked Jlink
    You lied, this is not segger software, we want to see how to use segger software to repair car program, i also want someone to explain something to me, i have 5.31 version and will like go flash to 6.80+lib file, the question is how do you make the CP know that new lib file is in use, what do you flash to put in new lib file, please using segger, we need video for segger
  2. The Following User Says Thank You to forumoto For This Useful Post:
    bravel digital (4th June, 2014)
  3. #317
    Aug 2008
    There is only 2 lib files I know of 1 is for the 4.01 serial and the other is for the 4.74 serial
    What u do is program the 4.74 file to the carprog mcu then u can use the software with the matching lib file
    For 4.74 which activates more than the other
  4. #318
    Aug 2008
    Lib file is the software activation file for the set serial (4.01 or 4.74) in your case 5.31software with 4.01 lib and serial in flash
  5. #319
    thank you TANGO, for answering, but i am not clear here with what you mean by program profile the 4.74, i have seen 6.80 software with lib file which when you compare the size it is bigger than 4.x lib file, now i have also seen here that the flash bin file for at91 is that only for 4.x version or what, how do you make the carprog know you have a new lib file, whereby it will KNOW it
  6. #320
    I am looking for a version that ACTIVATE VOLVO transponder section
  7. #321
    Aug 2008
    Quote Originally Posted by forumoto View Post
    the lib file is the serial number ( 081105CAR001773I.lib = serial number for the 4.01 activated softwares, 201213CAR000ME61.lib = serial number for 4.74 activated softwares any newer i have not seen).
    you would need the flash file too to match the lib file
    ie at91sam7s256 -sn-m61.bin goes with 201213CAR000ME61.lib which will give u only what software version 4.74 activates, for anything newer ie 6.80 you would need the flash and lib from an original with that software etc
    so has there isnt any newer flash and lib files we can only use the 4.74 files and only have activated what is activated in 4.74 nomatter what software version we use.
    if programmed with 4.74 flash or 4.01 flash this is all we are stuck with
  8. #322
    Quote Originally Posted by tango View Post
    Now, i finally understand, so this means flash file walking on the net is for 4.x version not that it can be use for 6.80
  9. #323
    Aug 2008
    exactly we only have the flash for 4.74 therefore we can only have activated whats activated in that version
    untill someone dumps newer flash etc
  10. The Following User Says Thank You to tango For This Useful Post:
    Dodgyknees (11th May, 2019)
  11. #324
    Apr 2011
    Hi Guys,
    I have ordered a wiggler to reflash my carprog. I am a little confused, does anyone have the pinout from to and from wiggler please?
    Regards,
    Jules.
  12. #325
    Aug 2013
    Where to connect the NRST on carprog to 20 pin Jtag? Connect with pin 3 or pin 15 on Jtag 20 pin interface?
  13. #326
    Apr 2011
    Do you mean the wiggler?
  14. #327
    Aug 2013
    Yes, I can reprogram carprog with j-link. This is OK?
    carprog ---------------- jlink
    tdi --------------------- pin 5
    tdo -------------------- pin 13
    tms -------------------- pin 7
    tck -------------------- pin 9
    gnd ------------------- pin 20
    nrst ------------------- pin 15
  15. The Following User Says Thank You to radrad10 For This Useful Post:
    A630V (14th September, 2018)
  16. #328
    Some advise is needed for making the homemade Jtag with LPT port, please want to know the the value for the resistors, and should it be Kohms or ohms
  17. #329
    Aug 2013
    try these settings
  18. The Following 11 Users Say Thank You to radrad10 For This Useful Post:
    A630V (14th September, 2018), ADEL.KSHLAF (1st February, 2018), birocip (21st March, 2015), bram380 (20th June, 2014), Faraday (29th June, 2014), jurik8 (1st December, 2014), maremuruk (15th June, 2017), mexanico1971 (8th October, 2016), MiH (8th October, 2014), olo_3 (17th December, 2015), sbakovi (2nd November, 2014)
  19. #330
    Aug 2013
    good luck my friend
