if that dont work then leave pin 55 disconnected
then try
after reprogramming then connect pin 55 to gnd
all should be fine then
then try
then do as i said in other post disconnect pin 55
reprogram mcu
now test
hi, desperate need file .bin AT91SAM7S256 with serial 081105CAR001773I
thanks in advance
by the way !
Maybe configuration of segger project writes and read different sizes of content !
Because file to flash have 1,65kb , I read flash after write and segger read 616kb , if I read sectors to give 256kb file !
Another thing , some one say that Gnd pin isin"t was conected to nothing , Wrong !
check the pic
At88sc is semilar to 24c1024 ?!!
I use willem to read it and it give all FF FF FF.
I found AT88sc dump in web , but I try to write it and willem says "ACK comand error " same error as 24c02 is burn or dead
My work is my life ART TECH GARAGE
you had no reason to try to read at88sc
its documented not to try to do this otherwise you kill the contents
only option for you now is to buy another carprog unit
mexanico1971 (20th November, 2016)
struggled with carprog also reflash , brake leg on mcu , struggle then not regonise usb device then it works then it do not then antenna not work and next day it do , make rework all good then counter start again , time spend on struggle = could have bought 4 clones , from what i have seen once this thing starts with problems make a little rework to get basics running and order just main unit for replacement but most clones u get ver 4.01 and not happy make reflash jipee all good then struggle begin again = buy good quality online version clone and almost all problems at an end
Finnaly I could upgrade my carprog using an old PC with LPT and H-JTAG, no special programmer needed
When using LPT choose manual pins in h-jtag for LPT, configure by this schematic
Left pin 55 disconnected while programming, after the job is done, put it back on GND
100Ώ and 33Ώ resistors did the job
hello , solution from this thread is working also i was able to restore carprog antena for transponders. Now if your carprog reflashed , show you unknown device , first power up with 12v external supply , and after 20 sec connect USB cable.For me this is working so i'm another happy user . Hope is usefull for somebody .
babilon (27th September, 2017)
hello,
looking for instructions for flash carprog with ulink2?
anyone can assist?
many thanks
SOLVED -
Last edited by thayer201; 14th November, 2016 at 12:53 PM. Reason: SOLVED - USED JLINK INSTEAD
If i helped.... please dont forget to press the THANKS + REP buttons .
Hi bro, files not found. Could you please upload again. Thanks.
Hello,is there any chance to get 8.21 firmware,regards
Thank you all for your suggestions and unique experiences. A problem arose that when I connect my car prog to a computer, a message pop ups saying '' usb device is not recognized'' code 43. Any help please.
Thank you again for your valuable suggestions.
Hi, this is do to a problem of communication with your interface! first test or change the usb cable,if notpen interface and look for bad soldering point & or bad powering
(ther's a regulator for that),if also not resolved :so you can try to reflash your interface (look here in forum there's a step by step to do it),and finally if there's not a result :you must think to replace the mcu or the interface it self....regards
