Page 34 of 51 FirstFirst ... 24293031323334353637383944 ... LastLast
Results 496 to 510 of 761
  1. #496
    Dec 2016
    Hi all, I have anyone can bin carprog v8.21 ??? I no longer have the strength
  2. #497
    vanos batam's Avatar
    Batam-Indonesia
    Default bin
    some one selling this dump.... i dellet it
    pls testAttachment 418396
  3. The Following User Says Thank You to vanos batam For This Useful Post:
    leotdx (24th January, 2017)
  4. #498
    Aug 2008
    and you dont have the lib file?
    this is v8 offline
    150428CAR00491KW
    150428CAR00568KW
    MYKO201607010014
    are all the same bin and lib files
    this 1 posted is MYKO201607010014 which is fw 8 offline
  5. The Following User Says Thank You to tango For This Useful Post:
  6. #499
    hello to all,
    i need bin file for the flashing mcu
  7. #500
    in post 497 you have
  8. #501
    Aug 2008
    dont you mean post 497?
  9. #502
    with whitch lib did this bin work friend
  10. #503
    Aug 2008
    read my post above and find the any of the libs with either serial i posted above and use that lib file but change the number of the lib to the serial of which bin you download as they are all the same dump but with changed serials
  11. The Following User Says Thank You to tango For This Useful Post:
    mikroel (25th March, 2017)
  12. #504
    Sep 2013
    If anyone has a newer lib file?
  13. #505
    Aug 2008
    Quote Originally Posted by pike View Post
    how new do you want ?
    only newer lib files there is are version 8 lib files and they are posted here look for them
  14. The Following User Says Thank You to tango For This Useful Post:
    pike (4th January, 2017)
  15. #506
    Sep 2013
    Quote Originally Posted by tango View Post
    Several functions may not work with these files, although these features are seen as activated in the software.
  16. #507
    Default carprog
    .Test and raprot i thing is working.one is without pass.
  17. The Following 6 Users Say Thank You to xtech For This Useful Post:
    ADEL.KSHLAF (24th January, 2018), Domi (6th February, 2017), hoangtu (28th March, 2017), mikroel (5th January, 2017), Patrone (6th March, 2017), pike (4th January, 2017)
  18. #508
    Sep 2013
    Thanks, I have this file. With it the same problems.
  19. #509
    Aug 2008
    Quote Originally Posted by xtech View Post
    Pass pm .Test and raprot i thing is working.
    why password it ???
    it is the exact same lib file has the 1 i posted without a password
    150428CAR00491KW
    150428CAR00568KW
    MYKO201607010014
    020117CAR0000021
    all same files with dif serial numbers
    download any of the above lib files and rename then to whichever your serial is (providing its one of the above)
  20. The Following 2 Users Say Thank You to tango For This Useful Post:
    ADEL.KSHLAF (24th January, 2018), leotdx (24th January, 2017)
  21. #510
    frinds,i need chmatic to build a Hjtag from LPT port,please help
