Page 39 of 51 FirstFirst ... 29343536373839404142434449 ... LastLast
Results 571 to 585 of 761
  1. #571
    Dec 2012
    hello i desesperate searching for v8.21 .bin .i read all the posts but there are just old links how not works can some body helpe me please.
    sorry for my english.regards
  2. #572
    Nov 2015
    Quote Originally Posted by tango View Post
    That fw always gives Crc error because it's wrong
    Well, now I am a litte confused. Whats wrong about it? I mean, how can I tell a good from a bad one.
    I am really not trying to bag for the software here, but it wasnt directly easy to find the two files I got so far.
    And both of them are producing those CRC messages.
    Could you tell me what to look for , in order to get a good file? Or was that discussed already and I simply didnt see it?
    Thank you guys for the help.
  3. #573
    Trstenik - Thun
    Default Carprog Mcu Reflash Step by step
    Quote Originally Posted by Urmel View Post
    You must find good one bin+lib
    And get OK after testing .
    But first of all you have to repair your device with good chips!
  4. #574
    Top Poster zapdus's Avatar
    Jan 2017
    Hi, can you help me?
    I read a lot and spent a lot of time looking for carprog repair after tokens spent
    I removed eprom AT88SC from board
    Then lift pin 55 and connect to erase
    When I connect J-Link I always have this error
  5. #575
    Trstenik - Thun
    Quote Originally Posted by zapdus View Post
    Put better resolutions picture,Can't see what is error message
  6. #576
    Jan 2017
    Default Sorry
    Quote Originally Posted by mikroel View Post
    Sorry, here it is
  7. #577
    Trstenik - Thun
    Sorry, here it is
    If the connections ok then it seems to me that you didn't erase entire MCU.
    Try again to erase and leave MCU at least 30 sec connected on Vcc
  8. The Following User Says Thank You to mikroel For This Useful Post:
    zapdus (4th May, 2017)
  9. #578
    Home
  10. The Following User Says Thank You to Domi For This Useful Post:
  11. #579
    Nov 2015
    I only had connection problems when I didn't erase the ?P correctly.
    1. You need to first lift Pin 55 and connect a wire to it.
    2. Then (with the other end of the wire not connected to anything, power up the board (count 10-15 seconds).
    3. And then connect the end of the Pin 55 wire to 3.3 Volts and keep it there for 20 seconds.
    4. disconnect the Pin 55 wire and connect your J-Tag. Power the board up and try reprogramming it.
    By the way, I got mine to work now. The CRC error came from using the wrong firmware image.
    A functioning version of it (8.2.1 offline) is available on this board though.
    Thank you all for helping.
    By the way, what frequency do these RFID transmitters (IR48) use?
    I mean, what frequency needs the oscillating circuit be adjusted to? 125KHz?
  12. The Following User Says Thank You to Urmel For This Useful Post:
  13. #580
    Jan 2017
    Thank you all
    I will try again tomorrow, maybee it was bad erased mcu??
    Tomorrow I can tell you
  14. #581
    Jun 2015
    ARABIAN
    Do you have any manual that can help me do it just like you ???
    My carprog is version 7.28
  15. #582
    Feb 2017
    Czech Republic
    I have this device 020117CAR0000021.
    I have two exe files - one of them also with online diagnostic, so I can read also KM od Golf VI 2014, but it cannot write - error no permision :-/
    Mainly I wanted to do VW Golf 5 with micronas, but it cannot connect - no read, no write. Usually nobody have problem with micronas, or not? :-)
    Neither Audi A3 2007.
    Can somebody help please? Should carprog be change to another bin and lin?
    Thanks a lot,
    Daniel
  16. #583
    Nov 2015
    Are those devices of yours cina clones? As far as I know, some online funktions do not work with the chinese clones, since the software only fakes the online connection, without providing necessary data.
  17. #584
    Feb 2017
    Czech Republic
    Yea, it's china clone
  18. #585
    Nov 2015
    Well, in this thread you find all you need to reprogramm the processor of the board.
    There is another thread here called 'everything carprog' or so, that contains the actual 8.21 firmware.
    But that is an offfline version. there is supposed to be a version around, which has complete online
    functionality, but I do not have it, and I do not think its available for free. Someone may correct me, if I am wrong.
