Page 45 of 51 FirstFirst ... 354041424344454647484950 ... LastLast
Results 661 to 675 of 761
  1. #661
    Nov 2017
    Resloved!!
  2. #662
    ...AT88 krypto memory dead...
  3. #663
    joker01's Avatar
    Jan 2018
    hello guys .... problem .....
    I reprogrammer with success atmel ... now carprog no longer recognized by pc ....
    device not attached ....
    help thanks ...
  4. #664
    Trstenik - Thun
    Home
    Quote Originally Posted by joker01 View Post
    help thanks ...
    Keep in mind, English is not my native language.
  6. #666
    joker01's Avatar
    Jan 2018
    ok someone has files for e2p at88 ....need activation code after???
    during reflash the memory was removed, as it did to corrupted......
    ok someone has files for e2p at88 ....during reflash the memory was removed, as it did to burn
  7. #667
    Home
    Check soldering, but no dump for at88...or reflash again MCU
  8. #668
    joker01's Avatar
    Jan 2018
    ok........thanks
    I can find any dump for e2p carprog or I have to throw everything???
    the last firmware to load is 8.21 ???
  9. #669
    joker01's Avatar
    Jan 2018
    tried to reprogram mcu but I have clock frequency error.
    I think mcu is not deleted ......
    is there any other way to cancel mcu ???
  10. #670
    Home
    Post #429
  11. The Following User Says Thank You to Domi For This Useful Post:
    joker01 (1st December, 2018)
  12. #671
    Trstenik - Thun
    Cancel MCU??
    You mean erase MCU?
    lift and Connect pin 55 to 3.3V
  13. #672
    joker01's Avatar
    Jan 2018
    Yes...i lift 55 and connected to 3.3v to delete .... but always clock cpu error
  14. #673
    Trstenik - Thun
    Try to leave pin connected few seconds more , maybe few minutes .
    Check does 3.3 V exist .
    If it doesn’t help then your MCU is broken
  15. #674
    joker01's Avatar
    Jan 2018
    yes 3.3v is ok.......
    I'll try the solution of Domi with connession h-jtag......
    question connesion for h-jtag is usb or lpt??
  16. #675
    Trstenik - Thun
    Htag is LPT
  17. The Following User Says Thank You to mikroel For This Useful Post:
