mrchip // Bad soldering on header PCB or bad wires ( maybe wrong connected to programer J-link // NRST to RESET )
I do it without problems![]()
pollito128 (9th May, 2021)
friends maybe can me give dump AT91SAM with fully active ecu vag and online version +lib?
sorry for me bad english.
I can read edc15 edc16 eeprom with carprog and A1 adapter via obd?I try but not work![]()
guys have carprog sn 150428 car00542ua,which is the latest firmware available .... I have already killed a mcu I did not want to use a wrong file...
thank you so much...
guys I changed 2 new mcu but j link does not recognize me any of the 2 ..........
I tried to pin 55 to 3.3v for several minutes but nothing ..... where am I wrong ????
pin 55 is in short connection with GND pin 60 check this
removed older post
I see 6 cables connected, in my instructions I have 7 cables to connect..........
the first on the left on vtref of jlink
the pin 55 mcu raised must be shorted with 60 mcu pin ???
I do not have any shorts between the 2 pins
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
solved guys !!!!!! I unsoldered and resolded mcu, maybe a few feet was not ok.
I loaded firmware 8.21 with file lib 150428, some protocols are still blocked example airbag alfa romeo bosch 50527474.
it's normal????
Test HW with adapter.
Keep in mind, English is not my native language.
I have to build a test adapter ..... but it is correct that some protocols are still blocked???
