Page 6 of 51 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 761
  1. #76
    matekhr's Avatar
    Croatia
    Quote Originally Posted by djdanny View Post
    h-jtag error can't load h-jtag.dll
    Hello!
    h-jtag flash say: error: can't load h-jtag.dll
    on windows 98 LPT1 port
    Plase help!
    I try write AT91SAM7S256
    It's a known problem on Win98. I don't know is there a solution.
    You'll have to use WinXP.
  2. #77
    Jan 2011
    Alger
    I can't find it!!!!
  3. #78
    Jun 2012
    i try install xp oldies notebook.
    Work only XP!
    Thank you!
    Carprog Uploaded
    Many thanks!
  4. #79
    audiotek's Avatar
    May 2011
    Default New issue with Carprog clone 4.01
    Yesterday I tried to use my carprog clone but doesn't work, the serial number was changed to "yyyyyyyyyyyyyy". I think this happen for use the software version 5.05, before using this software everything was ok, after a few uses the serial number changes to "yyyyyyyyyyyy". I can make it work again reflashing the ARM, now all is ok.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  5. #80
    adam28's Avatar
    May 2009
    UK Essex
    hope you didnt update your hardware....
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
  6. #81
    audiotek's Avatar
    May 2011
    Quote Originally Posted by adam28 View Post
    I doesn't update my hardware, only use a few times the Carprog v5.05 and suddenly the serial was changed to "yyyyyyyyyyyyyyy". After reflashing my carprog clone works well.
  7. #82
    Nov 2012
    ESPAŅA
    hello to everyone, and tried to reprogram my carprog, but e had several problems, the first attempt to erase the at99, as I do but then I connect explicastes carprog to enter the program and would not detect it, is this normal ?.
    And another problem when I try to detect the target I get error tells me that is not powered or has no drivers etc, but it turns out if you have the drivers installed and turned on the light if someone could help me, thanks
  8. #83
    audiotek's Avatar
    May 2011
    Quote Originally Posted by 5555 View Post
    You need to follow the steps correctly, you don't need any drivers to reflash the carprog because you will not use the usb connector, you only need to use the HTAG connections inside the carprog. What programmer are you using to reflash? You need to be more specific to get help, if it's possible take a snapshoots.
  9. #84
    Nov 2012
    ESPAŅA
    and used the jtag that I recommend is the second photo of the first page, and followed the steps but whenever I try to search the targety always get the same error which is: "unable to find target. please make sure That the hardware is properly connected and powered up. jtag for mcu with multiple controllers, please Also Ensure That the tap be ACCORDING configuration has been. "Steps also software and followed him. What and used since my laptop has no parallel port usb to parallel uncable, not whether or not there will be failure
  10. #85
    Nov 2012
    ESPAŅA
    My connection between carprog and jtag is:
    1-vdd
    3-NRST
    5-tdi
    7-tms
    9-tck
    11-gnd
    13-tdo
  11. #86
    PIn 3 is wrong try with rst.
  12. #87
    matekhr's Avatar
    Croatia
    Try to connect your wiggler interface directly to LPT port, without any extension cable.
    NRST should be OK. Also try VDD on pin2, and GND on pin(s) 4, 6, 8, 10, 12, 14, 16, 18, 20.
    Good luck
  13. #88
    Aug 2012
    West Europe ,Latvia
    I have Jtag programm- verify O.k .
    Carprog after reflash dont connect via usb . DEVICE NOT CONNECTED.
  14. #89
    Nov 2012
    ESPAŅA
    Quote Originally Posted by branimirj View Post
    With three connected to pin JTAG reset?
  15. #90
    racin-snake's Avatar
    Jun 2009
    try the pinout fron inside the jtag unit mine was a cheap chinese effort pin 1 on the ribbon was in the wrong side (red line was reversed
    make sure the pins stated from the jtag interface are correct first !
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
