Results 91 to 105 of 761
Threaded View
    audiotek's Avatar
    May 2011
    Default Carprog Mcu Reflash Step by step
    Here is how to reflash CARPROG Mcu AT91SAM7S256 step by step, first of all I wish to thanks to lupu_sandu, elchip, autocargo, Tachonow, carradio2001 and all DK forum members who made this possible.
    I bought my Carprog clone 4.01 from digi_obd but after about 50 uses starts a counter: "260 uses left - update hardware to synchronize" and was decreasing, anyway 260 uses is big number to recover the investment (us $209 dlls), the programmer was paid before the counter starts.
    Ok, first we need this stuff:
    1.- AT91SAM7S256 bin:
    http://www.digital-kaos.co.uk/forums...og-rev-0.3.rar
    2.- Jtag programmer:
    3.- Jtag software:
    http://www.digital-kaos.co.uk/forums....1-release.rar
    We need to prepare the Carprog to connect to Jtag programmer but first the flash need to be erased, the Jtag function in mcu is dissabled, you can't connect to the mcu before erase the flash. Remove the AT88SC eeprom from the board, please note where is the pin 1 in eeprom before remove:
    Carefully lift the pin 55 (reset) of the mcu and solder a wire and secure it with a small ammount of silicone (you don't want to broke the pin in the process).
    Connect the Carprog (with the pin 55 dissconected) to the 12v supply, wait about 10 seconds and connect the wire from pin 55 to Vcc (3.3V) in Carprog:
    Wait from 5 to 10 seconds after connect the 12v supply, the flash content will be erased and the Jtag option of the Mcu will be enabled now. If not work leave connected for about 3 to 5 minutes. Disconnect the 12v supply from carprog and remove the pin 55 wire from vcc. The pin 55 must remain disconnected until the programming process is done.
    Install the H-JTAG software in your pc.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  2. The Following 55 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), ADEL.KSHLAF (27th January, 2018), Alfik (14th March, 2016), ali kaptan (27th October, 2022), angelx431 (23rd April, 2017), bravel digital (4th June, 2014), cheaper (4th March, 2014), Chokito5 (27th August, 2013), ciurkiempisane (4th May, 2015), Col19 (6th June, 2021), cole_mcs (6th July, 2013), cosmin12345 (24th August, 2014), csavargo2 (8th December, 2014), cuiuda (24th April, 2013), Danimp94 (16th March, 2019), deondti (2nd July, 2014), Dodgyknees (11th May, 2019), doud77 (5th December, 2016), fanos (17th September, 2013), Faraday (3rd October, 2014), gabi2014 (1st June, 2014), genius76 (9th October, 2013), Ginocar (13th October, 2013), hoangtu (17th April, 2016), jarripote (25th December, 2013), Jchip (7th November, 2018), jebson (12th August, 2014), jomberykaso (11th November, 2013), kalico (5th November, 2014), kukasIII (1st June, 2017), kuzmichh (4th May, 2013), leandroks (13th May, 2013), ligno1 (7th April, 2013), melectro (26th September, 2013), mihnea1986 (19th October, 2018), mohamedkey (18th August, 2013), monstermurga (16th January, 2018), narkeleptk (22nd May, 2017), nath15 (8th June, 2021), NELGLIDER (20th June, 2014), ozuque (6th December, 2016), pandokrator (6th November, 2013), ph0en1x (1st October, 2013), rm23 (29th September, 2013), rosak (31st August, 2017), sergei5005 (4th November, 2015), shadab (14th November, 2016), stromin (3rd April, 2018), Talleresmalaga (28th November, 2017), teamone (11th September, 2013), tk74 (19th September, 2013), traxpalicaru (15th May, 2019), tsanev (7th July, 2022), valty (28th April, 2016), yvespapou (23rd January, 2014)
