Page 8 of 51 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 761
  1. #106
    Nov 2012
    ESPAŅA
    Quote Originally Posted by sattvv View Post
    Hello
    I have dump for CryptoEeprom AT88
    I did some tests but without success
    probably wrong configuration and how they know it is a single programmable
    Can anyone help me with how to program this chip
    I work with BEEPROG programmer
    Thank you in advance
    hi could you upload the file AT88SC
  2. #107
    Oct 2012
    Thank you judor
  3. #108
  4. #109
    Aug 2012
    West Europe ,Latvia
    happy new year
  5. The Following 7 Users Say Thank You to judor For This Useful Post:
    ecufix (16th April, 2020), luco7 (11th March, 2014), martinracing (13th April, 2020), mexanico1971 (8th October, 2016), Patrone (6th March, 2017), zogic (27th June, 2019), zoro1 (9th June, 2019)
  6. #110
    Aug 2012
    West Europe ,Latvia
    Default CarProg A1 D1
    A1 + D1
    IZM Diagnostics: CarProg Full Project Files
  7. The Following 6 Users Say Thank You to judor For This Useful Post:
    ecufix (16th April, 2020), luco7 (11th March, 2014), luiggii79 (13th May, 2017), martinracing (13th April, 2020), Patrone (6th March, 2017), zoro1 (9th June, 2019)
  8. #111
    LT & ES
    Well, flashed my clone second time, so counter still ticking ...
  9. #112
    Oct 2012
    thank you it was your dump all my greeting AT88
  10. #113
    rm23's Avatar
    UK
    Big Thanks for hard work and solution !! reflash my carprog just for test its works !
  11. #114
    anyone buy from carsung?said is good quality and everythink else i take from carsung work great.they said is from first factory and it is good copy.what you said?thanks
  12. #115
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Hello m8s.Yes I have lot of devices from Carsung and everything is Ok,for now.Regards.
  13. #116
    Aug 2012
    Polska
    Mi a baj? My carprog clone dont, olvassa Fiat Stilo 2001 ODBII, ?s ne olvassa 95040 eprom. A9 adapter teszt OK! fenntartva 4 74HC125. K?rem, seg?tsen
  14. #117
    Aug 2012
    Polska
    What is the problem?
    My carprog clone dont read fiat stilo 2001 ODBII, and dont read 95040 eprom.
    A9 adapter test OK!
    reserved 4 74HC125.
    Please help
  15. #118
    Lithuania
    Quote Originally Posted by Pakli30 View Post
    A9 adapter test OK!
    reserved 4 74HC125.
    Please help
    Please don't spam on all treads. Use more time to search and read, and you find problem
  16. #119
    Serbia
    Question CarProg testing
    Hi dear friends! I re flash my clone carprog as directed, and he now works well.I tested with an adapter for HV test and everything is working correctly.
  17. The Following User Says Thank You to Dacha For This Useful Post:
  18. #120
    Nov 2012
    A friend lot better at debugging with ida said the eeprom can be removed from the atmel with a little work (and serial changed so updates work). Nice to read vag ecus via obd2. Also couple of actia flashes are going around some run 2011 fine some are incomplete. They can have the serials changed or in software bad serials removed.
