Page 9 of 48 FirstFirst ... 456789101112131419 ... LastLast
Results 121 to 135 of 761
Hybrid View
    Lithuania
    Quote Originally Posted by Pakli30 View Post
    What is the problem?
    My carprog clone dont read fiat stilo 2001 ODBII, and dont read 95040 eprom.
    A9 adapter test OK!
    reserved 4 74HC125.
    Please help
    Please don't spam on all treads. Use more time to search and read, and you find problem
    Nov 2012
    A friend lot better at debugging with ida said the eeprom can be removed from the atmel with a little work (and serial changed so updates work). Nice to read vag ecus via obd2. Also couple of actia flashes are going around some run 2011 fine some are incomplete. They can have the serials changed or in software bad serials removed.
    Jul 2011
    Thank's great job !
    I have a jtag wiggler like the one in the first pricture.
    How are you connecting the 25 way D type to the PC?
    I am plugging straight into the LPT1 but my pc keeps seeing it as an "unknown device"
    and a uSB device at that. But when I ren the H-JTAG prog change to LPT1 it says OK?
    Spent hours on it already, driving me mad.
    Aug 2011
    so sativ has been baned for saying the magick word combination? that he has dump for secret at88 ?
    Nov 2011
    friend and friend
    Default carprog
    hello good afternoon dk, puden help me how to use this programmer to repair my carprog, I have everything ready for J-LINK V8 Simulator. but not as used someone ever used this thanks for your help
    How to update Carprog and solve locked problem :
    Nov 2011
    friend and friend
    dk hi all, thank you very much I could finally solve thank you very much, especially because, audioteck, lupu_sandu, the chips, autocargo, Tachonow, carradio2001
    Feb 2013
    Romania
    Thanks alot ! I love digital kaos !
    Junior Member ERIG's Avatar
    Default UART1-ERROR
    hi i tested cp all ok also a1 ok only UART1-Error .is solution for solve this problem thank
    also ARM is little hot
    guys,spent hours to flash my carprog,without success.i use this programmer:http://www.anvilex.de/extern/documents/DS_P009_06.pdf
    don't know what i make wrong.
    pinout that i use
    1 vcc
    3 trst
    5 tdi
    7 tms
    9 tck
    11 gnd
    13 tdo
    connection are made without extension cable.did i need vcc from pin 2 too?
    if someone has ideas please let me know.
    regards
    Default INFO
    Quote Originally Posted by sepistar View Post
    pinout that i use
    1 vcc
    3 trst
    5 tdi
    7 tms
    9 tck
    11 gnd
    13 tdo
    regards
    MY CLONE ONE I WORK WITH IT NO PROBLEM NO CONTER
    Quote Originally Posted by 3abas27 View Post
    that's nice for you!but think that your answer are not related to my problem,even not in this thread.
    regards
  13. #13
    einet's Avatar
    Default Contibute to repair Carprog
    My contribution for this helpful Thread!
    After ask that I have problems with my carprog "pin8 have short to power"
    I put hand on it and resolve this in the best way!.
    So the problem is I bay a CLONE-FROM-CLONE-FROM-CLONE!!! With vary bad pcb layer
    On the micro and in all pcb.
    First to resolve my pin 8 problem whose the missing line on button pcb side and the hole whose not connected!
    Restore all and pin 8 whose GONE GONE.
    Second not read MCU Motorola or I2C or 95...., change all 74HC125D to 74HCT125M put a new cristal and condensators
    And all missing resistors on my pictures and make the new connection on the power socket so that I have more space to close the carprog housing without bending the pcb.
    And in the last modification is that isolate type! Is necessary IMPORTANT!, carprog have a separate GND and when put
    The PCB back in the housing sometimes have problems in read some MCU or eeproms!
    So I find out that the pcb in one side from the regulators make connection to the housing and make in
    The same time short to the another side from the PCB!
    Final Result
    Without put double 74HC125M (8x) to read I2C or 95 or MCU without or with external power
    My carprog read all without external power.
  14. The Following 15 Users Say Thank You to einet For This Useful Post:
    automocion (2nd May, 2014), car_soft_gorj (14th May, 2014), daxxer (1st May, 2014), electronistul21 (25th January, 2014), GolfmkI (18th October, 2014), jarripote (25th December, 2013), jenny123 (12th June, 2014), Mac Gyver (19th October, 2013), melvas (6th May, 2013), mexanico1971 (8th October, 2016), mohamedkey (18th August, 2013), Pali33 (1st May, 2014), Patrone (6th March, 2017), TheAlchemist (6th August, 2015), vomit (19th August, 2014)
  15. #14
    Quote Originally Posted by einet View Post
    ...put a new cristal and condensators.
    I check mine, the three smd capacitors, with capacitance meter and found the values are as in the edited photo, maybe by their wrong assembled on mine. But yours all are 100nF?
  16. The Following User Says Thank You to Zmann For This Useful Post:
    ecufix (16th April, 2020)
  17. #15
    einet's Avatar
    Quote Originally Posted by Zmann View Post
    OHHHH.
    Good to now this values!, i make a more fine tuning to my CP
    thanks.
    P.S the fotos what i put there is not my CP, i only take this fotos to show my CP repair.
