Page 12 of 51 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 761
  1. #166
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Can anyone confirm if this LPT parallel port jtag Programmer For ARM H-JTAG is valid to reprogram Carprog Mcu AT91SAM7s256. I guess if possible because is ARM7... but need you confirm this.
    http://www.ebay.com/itm/251216595416?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
    And further question is if i can connect this programmer to LPT port to Usb Cable Adapter and this not create conflicts to do reprogramming.
    Advanced Very Thanks for your help.
  2. #167
    Sep 2011
    In the Garage
    Can Anyone Help me Please???
  3. #168
    Mar 2013
    usa
    hi can u help me when i click on program 2-3 sec and a error: time out massage pop up
    thanx
  4. #169
    Lexas's Avatar
    Jul 2010
    Quote Originally Posted by ruffles1986 View Post
    i did with same programmer. it dont worked with my laptop, but with PC all goes perfect. Not sure about usb adapter.
    Don't Forget Button
  5. The Following 4 Users Say Thank You to Lexas For This Useful Post:
    benzerrouki (16th November, 2014), ferchichi (11th March, 2018), Oto kilitsan (16th January, 2021), ruffles1986 (1st April, 2013)
  6. #170
    May 2009
    're-flash possible without removing AT88SC eeprom'
    How many people have done this with full success? Any failures of the eeprom data yet?
    Could upa or xprog be used to read/write & backup this as a failsafe?
    Thanks guys for your help!
  7. #171
    May 2009
    Can someone please clarify a newbies confusion :-)
    #1 picture 4 shows the pin 55 link wire going to JP1 solder point nearest the USB end of the CP
    to enable flash erase. The next picture in #2 shows a link wire the other end of the JP1 to erase.
    Which is correct please?
    Credit to audiotek on making the programming software steps with pictures nice and clear!
    I understand that i can use the Ltp wiggler with the H-Jtag software to reflash the AT91SAM.
    If i want to use the usb J-link V8 does it still use the same software and settings?
    (sorry if this is a dim question...just trying to be foolproof - i should have asked on 1st April :-)
    Are the connections correct in #149 for the J-Link?
    Thanks to all
  8. #172
    Jul 2012
    Hello my Friend
    Can you help me please with this error from JTAG
    Can you tell me what I'm doing wrong
    Look the photo pleasefault from jtag.rar
    Regards
  9. #173
    audiotek's Avatar
    May 2011
    Quote Originally Posted by ChipDoctor View Post
    Hello my Friend
    Regards
    You'll need to erase the Atmel correctly, if you don't erase the Atmel content the Jtag port remains closed, pleaase look at post #1 : "Wait from 5 to 10 seconds after connect the 12v supply, the flash content will be erased and the Jtag option of the Mcu will be enabled now. If not work leave connected for about 3 to 5 minutes. Disconnect the 12v supply from carprog and remove the pin 55 wire from vcc. The pin 55 must remain disconnected until the programming process is done." For Jtag pinout check the post #2.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  10. #174
    Jul 2012
    I have erased the atmel 5-6 minutes to the ground because for 10 second does not erase
    May have burn the atmel? because I left it on the ground a little more than 5 minutes
    VDD of the photo is VCC from the jtag??
    TCK is TCLK from JTAG???
    NRST is TRST from JTAG ???
    The reset of the JTAG who to connect ???
    Thanks!!!
  11. #175
    Jul 2012
    Default CONNECTION JTAG-CARPROG
    Look this video please MOV02266.rar
  12. #176
    audiotek's Avatar
    May 2011
    Thanks!!!
    Erased the Atmel to ground? you'll never erase the atmel connecting the pin 55 to ground, as you can see in the post #1 the connection is to vdd test point of carprog, you need to make the erase procedure before to connect the carprog to the programmer. And yes, TCK is TCLK, NRST is TRST or RESET (doesn't matter, if you test continuity in programmer you can see that TRST and RESET are the same pin).
  13. The Following User Says Thank You to audiotek For This Useful Post:
    shadab (14th November, 2016)
  14. #177
    May 2009
    Quote Originally Posted by obd.tech View Post
    Thanks to all
    Can someone please answer the connection questions here please?
    To erase AT91SAM pin 55 linked to where? picture in post #1 or post #2 correct?
    Are the jlink connections in the picture post #149 correct please.
  15. #178
    Dec 2009
    BiH
    I still was not clear whether the use 74HC125 (CMOS level) or 74HCT125 (TTL levels)? I think that's the main problem with the clones....
  16. #179
    cubica1's Avatar
    Feb 2012
    Serbia
    Is somebody has pinout for RNS510 adapter..china clone has DB25 from one side and wires to second side...but, question is, where to solder wires on RNS510??
    The origin has conectors from both side.
    cuby
  17. #180
  18. The Following 2 Users Say Thank You to cosmind For This Useful Post:
    cubica1 (12th April, 2013), ecufix (16th April, 2020)
