Page 49 of 51 FirstFirst ... 394445464748495051 LastLast
Results 721 to 735 of 752
  1. #721
    Jan 2010
    Trstenik - Thun
  2. #722
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    buna ,work directly oly with A4 eeprom adapter ,you use D1 adapter .great job .
  3. #723
    Mar 2015
    hello i have a problem with MCU re-flash,my J-LINK get error when identify mcu(canot find cpu family and j-tag chain)...some like that,i folow intruction to conection and everything ok .help please
  4. #724
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by mtk motors View Post
    If your connections are good as discribed in instructions and If you can't find MCU probably MCU died or u just didn't erased MCU well,
    If it isn't erased well you can't connect to MCU by JLink
    Sent from my HONOR 8X
  5. The Following User Says Thank You to mikroel For This Useful Post:
    Stelaras26 (15th November, 2019)
  6. #725
    May 2017
    Quote Originally Posted by CVT View Post
    Is this a Chinese clone or the original? And which version is it?
    Is 4.74 the highest version that 4.01 can be updated to?
    I was able to update my Chinese clone to 8.21
    Did you write the bin file from wokcz s/n 201213CAR000ME61.lib ? that one is 4.74 is it?
    which bin file (what s/n does it put into carprog) for 8.21
  7. #726
    al70's Avatar
    Nov 2017
    Éire
    Quote Originally Posted by Stelaras26 View Post
    i have programmed 3 carprogs like this with a 10euros jlink..
    I dont unsolder anything from the back of pcb,i dont lift any pin of the mcu....
    much easier way,it took me 3 minutes each.
    wow, thanks for that, i was dreading trying to lift that little pin, my jlink is on the way, do you have a better pic of that soldered wire and anything else i should know reprogramming this way, cheers and goodluck
  8. #727
    al70's Avatar
    Nov 2017
    Éire
    ahh i got a good zoom now on the pic Stelaras26 are you bridging those two traces ? thanks.
  9. #728
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    carprog expert required
    hi lads i have an original unit but unit is playing up
    can i swap components to a clone board and will it work same as original
    hope someone can help
  10. #729
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by whiskeyman View Post
    Yes it it can work as original but up to Ver. 8.21
  11. #730
    Jan 2019
    poland
    Zamówiłem 4x 74HC125M / producent TI / i dostałem 4x 4x 57CG4NK HCT125, czy to dobrze?
  12. #731
    Jan 2010
    PL
    Yes, but you can check the quality at work
  13. #732
    Jan 2019
    PL
    looking for and can't find bin file 150428CAR00542UA. is available ?? is there any lighter charge of it ?? with better stability and functionality ?? thanks
  14. #733
    Apr 2019
    Hello all Mates.
    Does anyone done with this J-link model?.
  15. #734
    Apr 2019
    Quote Originally Posted by rybenz View Post
    Hello all Mates.
    Hello.. does anyone done?
  16. #735
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Same as any jlink mate!
