I am thinking of taking my box mobile in the caravan.
What will thenpicture be like if a used a internet donge and also when streaming how much usage will i need if say i have a 2gb allowance
If you have a decent 3g signal the picture should be fine. Re useage it uses very little and 2gb month allowance will be more than enough
my friend uses a 3g dongle and is running 2 boxes and it uses about 200mb a month if even and if u are running 1 box on a 3g dongle u will need a laptop connected and dwnload somefing like a torrent and set download to 1kb, if you dont the picture will freeze every 20 to 30 sec, this is because the box uses so little, so the dongle goes into standby mode, i have been testing this for well over ayear now, so the only way to get it workin without much freeze is 2 or 3 boxs or a pc or laptop downloading or uploading somefing at around 1kb
dreamuser12
Your box will use very little bandwidth.
The issue may be latency and the mobile provider, although T-Mobile does a cracking deal, it doesn't work well for boxes. Three mobile does though after a couple of weeks testing.......
Also, consider a mifi device, the T-mobile one works well and can be unlocked very easy for other networks.
SS
