Results 1 to 9 of 9
Hybrid View
    DK Veteran nibblitz's Avatar
    May 2010
    You have a channel list on it ? Select a channel, BBC1, get the signal strength meter up (info button) make a note of the strength indicated, then carefully pop the satellite feed out, look at the signal strength without the feed connected, compare to strength with feed in, if theres no difference then your box possibly has a faulty tuner...
    Aug 2012
    i am getting 70%-90% with lead in and with out lead only 43% so u think it could be the box and yeah i have a uk sky channel list on
