Results 1 to 2 of 2
    Jun 2012
    Default Extending [satellite] cables to another room
    Hi all,
    My Mrs has decided she wants to swap the lounge and dining room usage, which means I need to extend the cable feed from the dish.
    I don't want to run new cable if I can avoid it, but what's the advice on "extending" cables?
    I guess I have maybe four options:-
    Run new cables completely
    Use an in-line connector
    Find (buy/make) a passive "junction box" and use patch cables
    Find an active distribution switch
    I have two dishes, one fixed with twin LNB for Freesat, and one motorised with single LNB
    Opinions please?
    S
    Nov 2008
    ideally you should run new cables, but you should have no problems using barrel connectors (used with F connectors) and extend the existing cables with new cables with f connectors both ends and "barrel" them onto the old cables
    so options 1 or 2 yes, 3 or 4 no in my opinion
