as Ive seen you used Volta sw.
is there someone can confirm if this will work ?
please friends. I need help for this car
Mate u have PM .
Change the bytes in winols and make sure that checksum is correct.
Cheers
Dpf off, thanks to spawn (my teacher).
Pass pm
Correct checksum
You need erase dtc after make changes.
I test today and work like a charm.
Ps: I just change 1 location.
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
soot level reseted.
I have maf error implausible signal and check light on. maf was replaced with new one
Mate ur problem is not the DPF . the DPF bytes are correct .
good job ecutuners
Need all sensor ok. Bad solution. If the DPF sensor or temperature breaks - that you tell to the client? Bad decision. Better already ecusafe))))
