Results 1 to 15 of 25
    Oct 2008
    Default vu duo not switching on
    i havr a clone vu duo for 6months and today it stopped working. i changed fuse but stil doesnt work. it smelt like something has burnt inside the box. i think the power supply has gone can someone tell me what the problem could be. thanks
    Sep 2008
    Sounds like the PSU, known problem on both early and newer batches
    DK Veteran portbhoy's Avatar
    Sep 2008
    Order a new PSU from Mixeshop around ?20 delivered.
    Mar 2011
    Be a man and open it up and check out the PSU Look for either burn marks or components that have exploded, if unsure post some pics here.
    Oct 2008
    can the current psu be fixed?
    Feb 2012
    Depends on what's gone wrong with it and what your soldering skills are like.
    Oct 2008
    ok i dont knw much abwt them so il post image of it on here and my soldering skills are ok
    Sep 2008
    has anybody fixed them by soldering bits in,would think a board be the safer option.
    Sep 2008
    You'd not be a man, you'd be a fool trying to solder caps on a 240v psu if you don't know what you are doing or know how to discharge some of them.
    Just order a new PSU and be done with it.
    Oct 2008
    im going to give to my mate who know fixed psu he may be able to fix it if not then il get a new psu.
    Oct 2008
    also if i get it fixed or buy a new psu will it blow out again?
    Sep 2008
    quite possible as the build in clone boxes lately is a disgrace.
  13. #13
    Oct 2008
    this is pics of the psu
  14. #14
    Oct 2008
    got new psu put it in and box works now. any ideas how i can make the new psu last longer. if i switch box off when not watching will dat help?
  15. #15
    Aug 2008
    Quote Originally Posted by asad5150 View Post
    that would be just luck, ya put it on standby when not used would be good idea, or even put it on deep standby, should be able to still record
