I did what you said with the SecurityLicenses.xml and it worked ...., so easy !
Remember guys, you gotta edit SecurityLicenses.xml, go to page 21 for understanding.
I have Insite 7.3 SP1 and it really worked !![]()
does anybody have the Cummins CEPC and Intercept for Heavy Duty Engines?
That is good! Thanks guys! The only problem mine is still expires on February 17. I think if we adjust our date on PC we will be fine. Hopefully.When I try to open it with let say March date it would ask for a new password, but when set the date to February it opens it ok.![]()
install insite 7.0 and work fine ,,,,delete insite 7.1 and up
hello please put the link to download 7.0 version of insite thanks
I think I found out what will happen on the 17th. i believe if you have a pro version you will still have a working insite.
Yes, but you need to install the drivers, download inline 4 and 5 drivers free from inline.cummins.com, or from the CD ROM that came with the inline adapter.
once the drivers are installed, connect the inline 5 adapter, and power it up from the "engine" end, click on RP1210 as device type, and select inline 4 or 5
yes, CEPC will time out. I should know, I purchased online before, was working fine and then it timed out suddenly. No reason at all. Probably better to use QSOL to find your parts required though you have to be online to do so.
