Page 54 of 126 FirstFirst ... 444495051525354555657585964104 ... LastLast
Results 796 to 810 of 1876
  1. #796
    While I don't know about insite 7.3 keygen, I can supply you with DDDL v6.4 and the crack.
    DDDL 6.4
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Crack for DDDL 6.4.
    This crack does indeed work for v6.4, I have installed it on several machines, but there were some... discrepancies...
    If installing on Windows 7, the crack instructions, which are at the bottom of this post, work fine, I had no problems installing it on my Win7 laptop. Windows Vista should behave the same.
    Windows XP, however, offered up more of a challenge. After several attempts, the way I found to work consistently was to follow the instructions included with the crack up to the point where you actually run the cracked exe, then enter ten random numbers for the key, once it says it is successfully registered, exit DDDL and reboot. Stop following the crack's instructions right there. Instead: Go to C:\Program Files\ and delete the *ENTIRE* Detroit Diesel folder, reboot, and re-install. The first dialog box to pop up after you run the installer again will want you to completely uninstall any previous versions of DDDL. Do *NOT* remove the "old" version, you overwrite what's already there (I believe the correct answer in this dialog box was "no"). After it finishes installing, reboot, run the program. It will be fully enabled.
    I came up with this method through trial and error and have used it successfully to install it on 6 XP machines so far. I would bet this method will work the same with Win 2000.
    EDIT: Original crack instructions (not written by me, C/P from another site):
    HOW TO INSTALL :
    To install on Windows XP and Vista For DDDL 6.4 Crack :
    To install on vista or xp follow these instructions. it is a lot
    but you MUST follow these direction exact or it WILL NOT work.
    Run the install for DDDL 6.4. program
    After install DO NOT run the progran. reboot your computer
    After reboot (do not run the program at this time)- Go to
    c:\program files\detroit diesel\diagnostics\ and copy
    "dddl.exe" and paste it to your desktop (make sure the whole
    file copies not just a shortcut)
    copy the crack dddl.exe file from the download to
    right click c:\program files\detroit diesel\diagnostics\dddl.exe
    and run as administrator
    enter any 10 numbers. the program will now open. let it open
    completely.
    close the progran and reboot computer
    go to c:\program files\detroit diesel\diagnostics\ and
    Delete dddl.exe and put the original file from the desktop in
    this directory. (do not copy over the cracked dddl.exe it must
    be deleted first)
    reboot computer again
    Now before you run the program you will need to go back
    to c:\program files\detroit diesel\diagnostics\ right click
    dddl.exe and go to properties. click on compatibilty tab and
    make sure run as administrator is checked. click on ok.
    Now you are done installing the program and it should run
    with no problems. Then install the 6.44ta upgrade.
  2. #797
    Insite 7.3
    PCID: 10A914A2
    Need all goodies.
    Thanks!
  3. #798
    Help me
    I need key PRO + PRO PLUS + ECM password removal + Fleet Calibration count in 7.3
    My PCID: 087E7308
    thanks and best regards
  4. #799
    DK Veteran zds's Avatar
    Russia
    I need the following codes:
    W=ECM Password Removal
    Z=OEM, ECM Password Removal
    F=Fleet Calibration Counts Available
    PCID 9F959665
    And if it is possible other codes (basic, pro, pro+...)
    thanks In advance
  5. #800
    I feel so stupid... how can I send you a PM. I can't find the PM link. I need Insite 7.3 keygen and hope you can explain me how to activate Incal, add calibrations and activate Zap-It. Thanks for your kind attention.
  6. #801
    Quote Originally Posted by padrinolalo View Post
    Just click on the persons name you wish to PM. Then scroll down to send private message
  7. #802
    Quote Originally Posted by undeadmechanic View Post
    DDDL 6.4
    Crack for DDDL 6.4.
    HOW TO INSTALL :
    completely.
    be deleted first)
    I have Winxp sp3 and I did the same stuff to get me dddl 6.4 to work, run crack enter 10, then delete and reinstall.
  8. #803
    lite password expired today
    can i get pro, pro plus and ecm password removal
    for PCID B56293BC on insite 7.3
    thanks in advance!!
  9. #804
    Quote Originally Posted by SteveOFF View Post
    Enjoy...
    Basic: 000439CCF8CBF6433L
    Pro: 002B52138622C9E33L
    Pro+ : 0080EFD48DE2EBD33L
    Pro+ inactive, I can not active in this soft,so what Pro+ is used to do???
    Forgive Me, I'm a Chicken!!!!!!!
  10. #805
    Russia
    hello to all especially SteveOFF. I'm from Russia, so it can not write in English. It is necessary codes
    BASIC
    LITE
    PRO
    PROPLUS
    POWERGEN
    ECM PASSWORD
    ECM / OEM PASSWORD
    FLEET CALIBRATION
    My id 5CB4D9C7
    Version 7.03.2.196 SP3
  11. #806
    Russia
    thanks in advance
  12. #807
    Help me
    My PCID: 087E7308
  13. #808
    Quote Originally Posted by Firewerks View Post
    thanks in advance!!
    Enjoy mate...
    Pro: 0025D416D15210733L
    Pro Plus: 0084BC95D4C2A6D33L
    ECM: WSS7130305E569633L
  14. #809
    Quote Originally Posted by Molodoy View Post
    BASIC
    LITE
    PRO
    PROPLUS
    POWERGEN
    ECM PASSWORD
    ECM / OEM PASSWORD
    FLEET CALIBRATION
    My id 5CB4D9C7
    Enjoy my Russian friend....
    BASIC 000947B4A03085533L
    LITE 00123C6BCB0E4B833L
    PRO 0023BB3CD8B473733L
    PROPLUS 008BB7831BC80B333L
    POWERGEN 00406AF9BB50FE833L
    ECM PASSWORD WSSF49E2442B0F433L
    ECM / OEM PASSWORD ZSSC6D6FD2E497033L
    FLEET CALIBRATION FSS66CFBD750FA733L
  15. #810
    Quote Originally Posted by thanh_luckystar View Post
    Help me
    My PCID: 087E7308
    Enjoy mate....
    Pro: 002FEA4CEB642A633L
    Pro Plus: 00896777826CEE733L
    ECM Pass removal: WSSCDCEE138882C33L
    Fleet: FSS31F61795B6FF33L
