Page 66 of 126 FirstFirst ... 1656616263646566676869707176116 ... LastLast
Results 976 to 990 of 1876
  1. #976
    Glad to see this been looking for information on how to get this to work!
  2. #977
    Help me
    I need key PRO PLUS + ECM password removal + Fleet Calibration count in 7.3
    My PCID: EDD88A4D
    thanks and best regards
  3. #978
    Junior Member sara_suansun's Avatar
    hi, I need key please
    cummins 7.3
    PC ID F7BAE041
    Also looking for:
    [LEVELS]
    0=BASIC
    1=LITE
    2=PRO
    3=RSGR (Road Speed Governor Restricted)
    W=ECM Password Removal
    Z=OEM, ECM Password Removal
    F=Fleet Calibration Counts Available
    NO limited date
    Thanks in advance
  4. #979
    just uninstall cummins, instal the version insite 5.6.1 use the old keygen to generate ECM remuval password, Fleet calibration counts etc. upgrade to INSITE 7.2, use the crack available in this forum and ready, you have ECM password remuval and fleet calibration counts
    regards
  5. #980
    DK Veteran kaomde's Avatar
    Quote Originally Posted by dimitar22 View Post
    Any one?
    please
    000F5667A1CD99B32X
    Love, Peace and Music...
  6. #981
    DK Veteran dimitar22's Avatar
    Jan 2009
    Quote Originally Posted by kaomde View Post
    000F5667A1CD99B32X
    the password is not valid. Please new one. I realy need it.
    Thank you in advance.
  7. #982
    Default Just new at this
    I have spent several hours getting 7.03 to work olny to find that I dont have all of the codes I need.ECM password removal + Fleet Calibration count in 7.3Can anyone please help? PCID: CB3BEB06
  8. #983
    Quote Originally Posted by hercamp View Post
    to recalibrate cat u need stw flash files disc that u can find here in DK and youre cat ET need to full dealer key that u can get from the keygen ....and ofcourse is here in DK....how I ?ve seen the last one here is the 2008C flash file disc for engines until sept.2008.
    and............
    cummins insite is used for diagnostics in all cummins engines .....with a pro plus ID u can change all parameters in the ECM.
    if youre ECM is lock u need to have a ECM pass removal key.....if u need to change the HP in the ECM u need a fleet calibration acount (keys) and an actived INCAL dvd that u can find here IN DK.
    whit the recalibration u can change the rating ...example 430hp@2100 rpm to 500hp@2500rpm .
    and........if this info was useful for u dont forget to press thanks
    I download INCAL but I don't know how to use it...so please guide me how...Thanks Pro
  9. #984
    i need cummins keys 7.02.0.362
    PC ID 8EFDA5A3 for:
    [LEVELS]
    0=BASIC
    1=LITE
    2=PRO
    thank in advance for hany help
  10. #985
    DK Veteran mondao's Avatar
    Quote Originally Posted by truckservice View Post
    1-first download incall 03/03/2010
    2-copy the contents of the DVD at: C: \ Intelect \ Insite \ CalibrationWorkspace
    3 -: open insite, connect with the vehicle
    4-select the calibration menu
    5-and select the calibration you need, right click, send the ecm, and follow the steps below,
    6-it works for me so, someone correct me if I'm missing something
  11. #986
    Quote Originally Posted by mondao View Post
    After extract INCAL includes many folders, so we copy all folders to: C: \ Intelect\ Insite \CalirationWorkspace??
  12. #987
    Default insite 7.3
    Anybody purchased insite thru truck-expert.net or autocd.com?
    I wonder if it comes with crack or password. Anybody has a crack for insite 7.3 or is it gonna be the same as for 7.01? tnx
  13. #988
    so it must be to work
  14. #989
    Member Lukas roberto's Avatar
    brasil
    hello need keygen for cummins insite 7.02.0.362
    i am mechanic
    help?
  15. #990
    DK Veteran superc0's Avatar
    MEXICO
    Quote Originally Posted by Lukas roberto View Post
    i am mechanic
    help?
    you cant find the new kg on dk, read before all entire post and you can work with insit , in this post is the solution, read before or put your pc id.
    SOFT FOR ANDROS BENCH 6330 HELP PLZ.
