Results 1 to 11 of 11
    jebo's Avatar
    DURIAN CITY
    Default Autocom Clone "Flight Recorder"
    I just got a new autocom "china"
    tested it on some of Asian cars in my workshop
    And it seems to work well except for The "Flight Recorder".
    It fails when writing the template to the vci.
    For those who have china autocom here,
    does your Flight Recorder works?
    Thanks!!!
    Aug 2011
    Spalding
    Jebo
    Did you ever cure this problem? Mine is the same.
    (Operation Failed)
    Martin
    jebo's Avatar
    DURIAN CITY
    Quote Originally Posted by MJRVR View Post
    Jebo
    (Operation Failed)
    Martin
    No fix found yet.
    Now saving to get an original one.
    Jul 2012
    i have a clon and flight recorder is ok
    you need a microsd in the hardware, and then install Autocom.
    Good luck
    jebo's Avatar
    DURIAN CITY
    Quote Originally Posted by pollete View Post
    Good luck
    what size is your microSD?
    i put in a 1gig, but still did not work.
    "microsd in the hardware, and then install Autocom"
    do you mean that i should put in microSD in the hardware 1st before installing the software?
    Aug 2011
    Spalding
    Mines a 2GB micro formatted FAT32.
    I think the problem is in the Autocom, not the card.
    Theres internal memory in the Autocom that the template has to be written to.
    Does anyone know which chip the template is stored on?
    Martin
    Jul 2012
    hello
    sorry for my english
    * Autocom install with 2gb microsd
    the first run, you need to instal with Autocom microsd
    Autocom first start without card and it did not work, I returned to the Chinese.
    Autocom second set started with the card and everything ok.
    one day change the microsd and the flight recorder did not work .. I replaced the old microsd and all ok
    good luck
    hello
    good luck
    What is the tipe of your micro SD? kingston/verbatim/etc???
    Maybe this information will help.
    Jul 2012
    Quote Originally Posted by flavyus1987 View Post
    no tipe, only write ZHT in microsd.
    you can change de serial machine with microsd in vci and reflash 2011.3.5
    good luck
    jebo's Avatar
    DURIAN CITY
    good luck
    The working microSD Came also from china?
    Chinese seller send it to you with autocom?
    Jul 2012
    Quote Originally Posted by jebo View Post
    No.
    My autocom cdp+a no have a microsd.
