Results 1 to 14 of 14
    Jun 2012
    Default Digiprog 3 to PC
    hi all has anybody been able to sync there dump files from dp3 (Clone) to PC via etools Ive tried but haven't had much luck can anybody help please? Thank You
    ALEXEI's Avatar
    this sw work only with original tool
    batandball's Avatar
    May 2011
    I think if you look at etool that came with your clone its for diagprog 3 (DP3)
    not digiprog 3 unless chinks have change CD
    If it works use it
    BatandBall
    Jun 2012
    thanks all so is they no way to get the files of the digiprog clone to pc then ?
    ALEXEI's Avatar
    I have DP3 as it shows my avatar and I know how it looks this sw.
    can you post it here to see this called etool which looks like dp3 pc-link ?
    batandball's Avatar
    May 2011
    this is one that came with mine
    If it works use it
    BatandBall
    Jun 2012
    This is the file on the CD thank you
    ALEXEI's Avatar
    Quote Originally Posted by batandball View Post
    you mean this is original DP3 Elprosys pc-link sw ?
    wrong mate .
    if you want to see how it looks I can show you
    this is obvious Repsoft Digiprog 3 orig pc-link sw
    batandball's Avatar
    May 2011
    Quote Originally Posted by ALEXEI View Post
    wrong mate .
    cjeers nice to know
    but it does not work
    If it works use it
    BatandBall
    ALEXEI's Avatar
    please dont confuse DiagProg (Elprosys) with DigiProg (Repsoft)
    its a big distance between them
    batandball's Avatar
    May 2011
    i know difference between machines just not etool
    the cd wot came with digiprog clone had all diagprog PDFs on it plus that etool software
    If it works use it
    BatandBall
    ALEXEI's Avatar
    This is pc-link sw for DiagProg 3
    anyway not work for DigiProg clone
  13. #13
    Jun 2012
    so the software i seem to have is correct i just cant get them to talk maybe its a clone thing gonna look at dp3 towards end of year so for this clone digi has payed for its self
  14. #14
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Hi, who can give me all digiprog 3 manuals and pdf's, because I get it without any cd's. Thank you.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
