DPF by Volta, I think some errors, but not bad errors!
DTC tables remain.
EGR check engine light off, so disconnect or blank the EGR if you need.
DTC tables remain.
Hello and thank you for the file is correct it works well.
thank you again
He says file is good and working, what's the use of further comments ?
Read twice before you post!
I am talking about the ORIGINAL he posted. This file is not original. And the use of my comment is meant exactly as i wrote it: A reminder for the tuner in case problems come up where to start searching! And they will come up if someone combines Volta+ECUsafe+ *** on BMW EDC16.
If you have no use for it keep quiet please. My post does not affect you.
greetings,
filecloud
I am shure.
I have tuned that software several times in the past and so i have readouts which were 100% original and shurely untouched, because the customer had it updated on request at the dealer.
The software that has been posted looks like it has been treated with ECUsafe. A complete range of error codes has been zeroed out. Way more than necessarry for DPF and EGR.
greetings,
filecloud
thanks for the explanation
