Results 1 to 7 of 7
    May 2008
    Dublin
    Default Garmin SD Card Question?
    Hi i have a garmin nuvi 660, , memory was too small for the europe maps i wanted, so i download it on to a sd card. but when i put the card into the garmin, it dont show up, when i go to Map info" on the garmin, it only shows the in memory map, clicked off on the list of were to read from, when i put the sd card into the PC and go to my computer it shows the maps on the card, how do i get the garmin to read from the card only?when its not showing on the list to click off to read, thanks for your time and help .. ranger.
    have you got the right kind of sd card.
    Sep 2009
    In order to read from the sd card you have to named as gmapprom.img
    May 2008
    Dublin
    not sure what kind of sd card i should use, but its showing it loaded to the card i have?
    May 2008
    Dublin
    thanks for your answer, at what point do i name it, or can i rename it now?
    Quote Originally Posted by ranger View Post
    hi, i have the nuvi 760 and it has a sdhc card fitted.
    Sep 2009
    You can simply rename !
