Results 1 to 11 of 11
Hybrid View
    Romania
    Default Vw lt speed limiter remove
    can help me somebody to remove the speed limiter for a vw lt year 2003, edc15c4, 2,8 tdi. 0 281 010 587
    i've read the eeprom 95p08,
    many thanks.
    Fec001's Avatar
    I think limiter is in the flash
    Romania
    this means that must read the flash?
    In another post this edc15c4 have in eeprom the speed limiter.
    here is.... http://www.digital-kaos.co.uk/forums...-vw-lt-271531/
    whai can i do?
    Fec001's Avatar
    Did you try this?
    VCDS on engine/login 12233 .... adaptation/18...and write new value for limit
    tehnosoftex's Avatar
    Romania
    Default speed limit
    pass in PM
  6. The Following User Says Thank You to tehnosoftex For This Useful Post:
    illestibor (21st March, 2014)
    speead limit itis in 95p08 adess 68 69 put ff ff = 255km
  8. The Following 7 Users Say Thank You to vladtimmy For This Useful Post:
    autotuning (25th November, 2015), illestibor (2nd December, 2015), mariusf11 (18th July, 2018), massimo74 (3rd February, 2020), nikobg (26th November, 2015), rm23 (25th November, 2015), Rotor (12th December, 2023)
  9. #7
    Jun 2013
    EU
    , good answer after 3 year of the topic begining
  10. #8
    autotuning's Avatar
    Quote Originally Posted by morgano View Post
    Never too late if it helps somebody from today onwards do you not think?
  11. The Following 2 Users Say Thank You to autotuning For This Useful Post:
    Barry1 (24th September, 2020), nikobg (26th November, 2015)
  12. #9
    italy
    hi i try to remove speed limiter from my edc15c4.
    with vcds i can only go down,
    i try correct procedure, go to login digit 12233,adaptation channel 18,but a cn program only in down.
    i try to program with eprom 35p08 but not change my limitation value, i use another sw for eprom, do it immo off but i 've always limit at 100km/h.
    it's possible thet it's in flash?
  13. #10
    italy
    this is my original dump someone can help me?
  14. #11
    misamix's Avatar
    Sep 2016
    Serbia
    Can someone put limit to 88kmph?
    Car is VW LT, ecu edc15c4, eeprom 5p08
