Results 1 to 8 of 8
    Jan 2010
    Default Peugeot 407 sid803 dpf of
    Hi i have issue with peugeot 407,its have rhr engine with sid803 ecu,original ecu i kiled with first time connecting bdm.Byet spare ecu manualy svapped flasch and eeprom,car started.
    Now i readed and checsumed ecu,and please if someone can remove dpf for me.
    I readed with bdm 1255 c.
    Big thanks in advance.
    Top Poster + yas200's Avatar
    Jun 2012
    Estonia
    Quote Originally Posted by kojara View Post
    Correct removal - the DPF sensor need OK.
    Jan 2010
    File is pasword protected please pass.
    Jan 2010
    if anyone have file with dpf of please upload i wil try to kompare.Please
    Jan 2010
    Solved,with ecusafe
    Jun 2012
    Estonia
    If it not your car - it is necessary to prepare money for you on a major repair of the engine after ecusafe to pay to the client
    Sep 2012
    Default You need to reset
    Reset your card and that will help
    Jan 2010
    Thanks for warning.
    I found car from my frend with removed fap.rest its easy.
