Results 1 to 8 of 8
Thread: Faulty F3
    Jul 2011
    Default Faulty F3
    Just got a skybox f3 today and having two problems with it. The cccam.cfg updated fine, channels clearing etc. Updated the bouquet.
    The main problem is when I turn a channel on. Slot 1: Initializing comes up on screen. It won't go away.
    Secondly I've put multiple firmware files for the f3 on the USB drive and each one says file mismatch, when I tried to upload.
    Any help is greatly appreciated cheers.
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by anfieldoreilly View Post
    you could try taking the lid off and unplugging the card reader(if possible) and then re-flashing the box with 8-8-2012 f/w. regards mdt
    Jul 2011
    Quote Originally Posted by mdt View Post
    You mean screwing it open ? Would that not void the warranty.
    Also I can't flash as its saying file mismatch.
    DK Veteran lincsat's Avatar
    Jun 2008
    I would try downloading the firmware again and make sure you're not trying to flash a compressed file.
    You can flash by RS232 as well as USB, that may fix your problems.
    Apr 2011
    I have a friend who has the same problem. They have been away for a few weeks, and now when they switch on their TV & Openbox S11, they get this very same mesage: slot 1 initialising. Before they went away the box was working fine. Any ideas? Will it need a reflash?
    Thanks for any suggestions.
    Jul 2011
    I'd flash via serial. I need an adapter though. As I just have a standard 9 pin RS232 cable.
    By the time one comes from ebay I'd be just as better of sending it back to them.
    Jul 2011
    Sorry box is an m3
    Apr 2011
    I've got a null modem cable, so maybe I should reflash using that, although there is no reason a normal flash via USB shouldn't work?
