Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 83
  1. #31
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Quote Originally Posted by MHeptonstall View Post
    Also had to use pimpmywii to get EA Active fit 2 running from external drive.
    Is there any way to get rid of the 'update system' icon inplace of the disc icon, as I'd like to actually run from disc then we can fit two USB controllers (system us sufficiently updated as can play from hard drive back up)
    Well my EA Sports Active and EA Sports Active 2 work straight of so I don't know what you had to do to fix yours?
    As for allowing or not allowing disc updates I'm assuming you have PriiLoader 0.7 installed? Sorry that hasn't been mentioned on here because only one user has posted a sysCheck as requested so he had a PM. PriiLoader will stop online and disc updates. No ripped game should ask you to update.
    You can click the Thanks button under the posts that helped you.
    Keith
    2010 Golf GTD (170)
  2. #32
    happy_highlander's Avatar
    Aug 2010
    Games ripped and burned to disc will ask for system update as it is only by scrubbing games that the update portion is removed, scrubbed games can be burned to disc but as mentioned above priiloader will stop disc updates or if you are still not comfortable run the disc through neogamma 9 it won't install update and auto selects the correct cios to use.
  3. #33
    Aug 2010
    England
    Quote Originally Posted by happy_highlander View Post
    Is that only burnt games?
    Keith
    2010 Golf GTD (170)
  4. #34
    Aug 2010
    Quote Originally Posted by Keithuk View Post
    As far as I know all discs ask for update but the update should fail. My kids always use neogamma if the system update comes up just to be safe.But only games on disc still have update on them as converting to wbfs effectively scrubs the game and removes everything except the actual game file hence the reduction in file size. Wii backup manager gives you the option to load an iso into it and scrub the update section then copy it back to pc ready to be burnt to disc without the update section
  5. #35
    Sep 2012
    Quote Originally Posted by mapleleaf71 View Post
    @Keith
    Please check my answer inline:
    That sysCheck looks ok its exactly the same as mine.
    So did you find out why it wasn't leaving the sysCheck.csv on the root of the SD card?
    [maple] No. Going back to Wii "Home" where all the channels are listed means leaving the sysCheck.csv on the root of the SD card?
    So is everything working as it should do now?
    [maple] No, I can play all my downloaded games but some games allows me to go back to Wii's home menu and some don't. Wish I could get some help on this.
    __________________
    Keith
    Golf GTD (170) 2010, 5 Door
    Hi Keith,
    Did you happen to find any clue on my issue? I would really appreciate if you or anyone knows the solution on my issue - some games allow me to go back to wii home screen and some don't.
    Thanks in advance!
  6. #36
    Aug 2010
    Hi Keith,
    Thanks in advance!
    Are you sure it's not written into the game development that is stopping you going back to the home screen,,,, easiest way to find out is to put in your original disc which I'm sure you have as obtaining games you don't own the original of is highly illegal, get to the same point as you have on backup them press home button on wiimote and see if original goes back top home screen.
  7. #37
    Jan 2011
    Hi HH,
    Seek ur advise on how to make my Wii 4.3U to play downloaded games from USB source.
    This is my syscheck report.
    sysCheck v2.1.0b17 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Could not detect the drive date!
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x21
    Console ID: 132536894
    Boot2 v4
    Found 69 titles.
    Found 47 IOS on this console. 17 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/12/09.
  8. #38
    Aug 2010
    England
    Welcome to DK.
    Yes thats a typical Wii thats only been softmodded. Follow the instructions I posted in another thread.
    If you use ModMii with the SU option from a sysCheck. Now that you have the sysCheck.csv file.
    You can also read http://www.digital-kaos.co.uk/forums/f16/usb-loader-requires-least-cios-222-245-250-a-291481/
    Keith
    2010 Golf GTD (170)
  9. #39
    Dec 2012
    Default Having same issues with my Wii 4.3u
    Hello .. i just joined the forums .. i'm having the same issues with the error USB Loader requires at least cIOS 222 or 245-250 with my wii, but can't download any software recommended to help with trouble shooting .. please help?
  10. #40
    Aug 2010
    England
    Welcome to DK.
    Quote Originally Posted by dirrtyharri View Post
    Now you've made your first post then you will be able to download anything from the download section.
    Keith
    2010 Golf GTD (170)
  11. #41
    Jan 2011
    Welcome to DK.
    Hi Keithuk, I apologies for the late reply. Been busy with the year end events! I will look at the other thread and will keep you posted on the progress.
    Thank you for responding! Like to wish you and the team here a every Happy and good year!
  12. #42
    Jan 2011
    Hi Keithuk,
    Its me again. I have followed your post number #14.
    I have managed to updated IOS236 v5.
    However, I was not able to update the WADs on WAD Manager.
    It gives me a error as "Error Mounting on SD "
    I am using "Multi-Mod Manager 13.4"
    Please guide me ! Thank You in advance.
    Region: NTSC-U
    Drive date: 2008.12.18
    Hollywood v0x21
    Boot2 v4
    Found 70 titles.
    Found 48 IOS on this console. 17 of them are stub.
    IOS236[36] (rev 65535
    BC v6
    MIOS v10
    Report generated on 2012/12/31.
  13. #43
    Aug 2010
    England
    Quote Originally Posted by din76 View Post
    Hi Keithuk,
    Please guide me !
    Well if you followed my instructions in post #14 to the letter there shouldn't be any problems. I said to use ModMii and your sysCheck.csv file to download updated/missing wads. Thats new sysCheck is only showing you've installed IOS236 which is needed before you install any other wads. You still have 17 subs you need to reduce to about 5.
    I've never heard of "Error Mounting on SD" as the SD card had a full formatted FAT32 so it will show any errors?
    Turn the Wii off then back on and try to install the wads again.
    I did have a similar problem last year when the wads wouldn't install on a friends Wii. I knew every wad that was needed but they would install. My friend only visits once a month so I said bring it back next month which she did and they installed perfectly that time and I had changed nothing, that computers for you.
    Keith
    2010 Golf GTD (170)
  14. #44
    Jan 2011
    Hi Keithuk, Can guide me to a post where I can start everything fresh ? I am afraid I am mixing things up here. Sorry for the trouble.
  15. #45
    Aug 2010
    England
    Well your sysCheck is still the same as you posted in post #40 its a typical Wii thats only been softmodded with 17 stubs which you have to knock down to about 5.
    You need to download ModMii 2.3 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
    This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
    Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.
    You can run sysCheck again and post a new sysCheck report afterward installing all the wads.
    Happy New Year.
    Keith
    2010 Golf GTD (170)
