I get this error when loading usbloader USB Loader requires at least cIOS 222 or 245-250
Welcome to DK.
We need more info about youy system, post a full sysCheck as instructed in that link.
Keith
2010 Golf GTD (170)
i got the same error.
anybody else?
Can you please send me some info on how can I grab the syscheck info out of my wii 4.3E?
Thanks,
Mapleleaf71
Welcome to DK Mapleleaf71.
This is your first post so you'll have to wait 20 minutes before you can dowload anything.
Keith
2010 Golf GTD (170)
Hi Keithuk,
Thank you for responding! I have downloaded SysCheck from your site and got my report:
sysCheck v2.1.0b17 by Double_A and R2-D2199
runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.3U (v513)
Drive date: 2008.12.18
Homebrew Channel 1.0.0 running on IOS58
Hollywood v0x21
Console ID: 142975603
Boot2 v4
Found 80 titles.
Found 46 IOS on this console. 17 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/09/28.
Any helps would be highly appreciated...
Thanks agian!!!
Ok mapleleaf71.
You're the only one thats posted a sysCheck report in here so you're the only one that deserves an answer.
I've sent you a PM.
Keith
2010 Golf GTD (170)
Hi Keith,
Thanks for the PM. I had one question that I have not quite understood in your instructions. After downloding ModMii6.1.5 and run it from Windows, I get lots of options to select. I have selected whatever I felt appropriate in my case but I did not get any option to select or enter the answer for "On the main menu type in SU and type in the location of the sysCheck.csv". Can you please explain where exactly I should see or go to do this?
Thanks again!!
Hi Maplelea
I had the same problem but now I have sorted it.
Follow these instructions and see if it works for you.
Firstly goto http://www.digital-kaos.co.uk/forums...mmm-13-4-1978/ and download the file then follow these instructions.
Extract the the wads and apps folders to a clean sd card.
Make sure you have deleted all usbloader gx channels or forwarders from the wii . To do this you goto the wii options bottom left of the main page, select data management, then wii channels. Select any gx channels you have and delete.
Put the SD card that you have just extracted the the two folders to in the wii, and goto homebrew channel.
Select Multi Mod Manager and load it.
Reload to IOS236 (reload to another ios is at the bottom of the list) click it and select 236.
Navigate down to wad manager with wiimote (third one down) and press A on wiimote to select.
Press 1 on wiimote to select all wads for batch install, then press A to install.
That's it you are all done.
You now have two options. You can use this sd card to load gx from or you can copy the usbloader gx folder to wherever you normally have your apps folder for your other loaders and apps.
Enjoy this version of usbloader gx. The techy info for it is that this is USBLOADER GX 2.3 r1128 that runs on ios249 as default and has just been updated on 19-11-11 to run full nand emulation for game saves and channels.
This worked perfect for me and no everythin is running fine.
Hope this helps.
SkePticJM (25th August, 2013)
sposa3 install this Digital Kaos - Downloads - Full Cios wad pack you must reload to ios 236 to install these files properly...If you extract the pack to a blank sd card, I'm pretty sure I have set mmm up on this pack to auto load to ios 236 if it doesn't select load another ios (it's at the bottom in the main mmm screen) once on 236 select wad manager and select all wads (1 on the wiimote) i think. (it's been a long time) then install them. Now load your usb loader best to always reload to ios 236 as this is by far the best for installing into.
Hey. newbie here.
I am going to give this a go. Hope it works
Thanks all
Which part of my PM didn't you understand?
Download ModMii6.1.5 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
First of run IOS236-v5-Mod and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8.0 final pack
HH your giving away our secrets when users are to bleeding idol just to post a simple sysCheck when asked. Only mapleleaf71 has posted one so I sent him a PM with what was needed.
Keith
2010 Golf GTD (170)
Hi Keith,
Please see my question below on your instructions -
1. On the main menu type in SU - is it main menu of ModMii or Wii console iteself?
2. "and type in the location of the sysCheck.csv" - what do youu mean by this?
Thanks,
mapleleaf
