Page 6 of 8 FirstFirst 12345678 LastLast
Results 76 to 90 of 111
  1. #76
    May 2009
    Hi guys.
    I need to last update for diagan 2 with S/N 980541667900.
    Can anybody halp me ?
  2. #77
    antalya
    Default launch easydiag m.diag Does golo have offline and offline wants
    launch easydiag m.diag Does golo have offline and offline wants email xxxxxxxxxxxxxxxxx
  3. #78
    Jul 2016
    USA
    I have problems with Honda’s SRS systems , on newer 2013+ Honda’s when trying to recalibrate OPS seat sensor launch says “no communication to ECU or vehicle not equipped” and on older 2011 or older it says “calibration ok” but srs light still on and ops failure code.
    in past 2 weeks I had about 5 Honda’s that this happened.
    Another guy with autel MaxiSYS pro ms908p came and fixed these hondas in few seconds
  4. #79
    Jul 2016
    USA
    recently updated to x431 pro3, and its very unstable.
    Using it on Samsung galaxy s6 with yellow easydiag connector
  5. #80
    Member SANTI-MECCANICA's Avatar
    May 2009
    Hi.
    I have x431 5c. It tells me that empty memory can not be updated. Is there any way to make it work with the SD card that is not busy?
  6. #81
    hi i have a x431 (x-diag pro3 ),on a tablet, updates have stopped and it says "no network found " which is not so, version v3.11.029
    s/n 969190006845
  7. #82
    Nov 2018
    romania,bucharest
    hello to all. recently I became the owner of un "launch x431 quicheck".the problem is that the card was formatted amd the software is lost.I tried to register the product on x431.com for downloading the software.butit was impossible.Maybe the tool is too old (2012).For this reason I ask to you if somebody can help me with the software for this tool. the serial no. is 981290077800 VO, registration no. 981270077300 (from envelope),and dealer code is 343002A (launchiberica).Please,i need you help
  8. #83
    Nov 2018
    romania,bucharest
    Quote Originally Posted by dansir View Post
    good news.i recovered the card.now it is working.but it has only demo and obd2.i need un update.can somebody to help me?
  9. #84
    Nov 2018
    romania,bucharest
    nobody can help me with the update for this sn ?
  10. The Following User Says Thank You to dansir For This Useful Post:
    xdiagpro global (16th December, 2019)
  11. #85
    eliasole's Avatar
    I bought a used easydiag 3 yellow ,previous owner used cracked firmware ,i want to restore it and use it as original on ipad , can someone provide me ori boot files to restore it?
  12. #86
    Jun 2019
    insert an external SD card on tablet to make it work.5C memory is very little space couldn't load so much software volume.
  13. #87
    Jun 2019
    this is very old machine,launch stopped the new software update...very bad news
  14. #88
    Jun 2019
    Quote Originally Posted by eliasole View Post
    if you want to use it onto ipad just login through launch official easydiag app and download the software you need will be OK.But launch changed the policy you will have to pay the car you want first before downoad them.
  15. #89
    May 2008
    Change the screen I had the same problem.
  16. #90
    Dec 2019
    Quote Originally Posted by martin1234 View Post
    s/n 969190006845
    Software update expired!
