hello could you tell me or the bin file that downloads in the program
after downloading the bin for edc17c41 for mini the update of ecu failed more communication with ecu I would have liked to recover the bin in the program to write it to ktag thank you for your help
Hi all!!!
i will need your help to update and use our smartbox
LAUNCH X-431IV
serial number: 983290507620
production date 20150108
hardware V10.04
Software System: BPV12.20
What are the steps to follow .... ?
PS: my uncle brought it to me from Uk
no user no pwd no dealer![]()
Hi, i am new here.
My Problem:
I have buy a X431-Pro with the Red DBSCar VCI.
The Tablet Battery was down and i have fixed this Problem. Now the Tablet allready okay.
When i want Pair the VCI it dosent go. I can See a Blue and a Red LED. The VCI with the Serialnumber is Correctly to See at Android Tablet/Smartphones.
I have called Launch Europe and they say the standart BT Login codes are be 0000 or 1234.
I have test it at 4 Android Phones and Tablets. Anytime it say wrong Pincode for Bluetooth.
Can i reset the VCI BT Pin?
can i write a new Firmware to reset the Pin with PC? When i took it into PC it found a " LaunchViritualComPort " but it dosent found a driver for it ( Windows / 64Bit ).
The Manual say i can connect the VCI and Tablet with a Cable and update than the Firmware, but it dosent go with a OTG Cabel.
Can i Found the Loginpin into a Chip? When , it is Crypted or Realtext into the Chip?
Thanks 4 Helping
Have anyone Updated the X431 Tablet from Android 4.04 to a higher Version? That where be Great when that go......... i need the Update for the Greater SC Card.
Yes, i can. But your device is old, it was stopped support from Launch since 2018. At current, newest of software since 2018. If you want known more detail, please contact me PM
hie guys can any1 help with launch gds x431 smartbox software mine just stopped working
i fixing my dbscar5 after error message ( communication error with vehicle ecu )
i tray every thing with launch technical support but no result
i have only 2 solution
1- buy new dbscar it coast bout 250 $
2- fixing old one
i chose second solution
this is the method
https://youtu.be/YD372r1q9aE
I know this has been discussed but I've yet to get an answer from reading threads. I bought a 2020 x431 v from a guy off marketplace, it is completely legit but I haven't been able to get back in touch with the guy and I didn't get the activation code from him, I've tried contacting launch to no avail?
Launch can offer you activ code!
but i suggest register it to diagzone. (attention: once activated on diagzone you cant go back to original software)
it has more functions! even if its lets say "cracked version" its more advanced than original pro V , pro v+ etc
diagzone its pro3s software!
edit: keyboard issues![]()
If freedom is outlawed, only outlaws will have freedom!!!!
Stelaras26 (16th December, 2020)
my x431 not dpf regeneration
hello! I have a LAUNCH X.431 V+ PRO. Is there anyone who has announced how but does factory setup on the dashboard of a mercedes w211 model 2004
hi friends
i buy DIAG GUN V from reseller with 3 years guarantee and after 3 months, tool stop working
launch reply to check with reseller but this reseller not reply
who solve same trouble with launch ?
hello i want to inquire if i can get an activation code for a launch x431 mini pro...seems to have lost the code details
i have some data, files, archives and backups from X431, please put here images, pictures and exactly model from your scanner
Hello . Who Can help me activate DBScar2
