Results 1 to 5 of 5
    Jan 2009
    Default Import Fav Channels Lists Clarke Tech
    Hi many thanks for the support so far.
    I was wondering if it is possible to import or copy/drag a Fav channel list in one Clarke Tech session into another open Clarke Tech session?
    The reason I want to do this is so when I update my channel lists and I loss the fav channels I can just drag them back in from the previous saved version.
    If not, any other suggestions to avoid keep having to re-select them.
    Thanks in advance.
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by rruunneerr View Post
    Thanks in advance.
    if you mean can the chn list be uploaded from a clarke-tech
    and re loaded on the receiver ie: after a factory reset or onto
    anouther receiver,then yes you can i always keep a copy of my ct5000 hd cplus receiver on my computer to keep and re-load if i need to factory re-set etc: as for will clarke-tech sat list load on different ct models i dont know, the technomate chn lists load on other tm models and my ct 5000 chn list has loaded on my tm 6900 these receivers are very similar they are even made in the same factory the tm or ct softcams load on both models and when i post a softcam for
    the technomate models it's a clarke-tech softcam that iv'e kept updated for a long time now
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    Jan 2009
    Hi Benny,
    thanks for your feedback.
    However what I want to do is copy & paste a Fav channel list created previously into an updated satellite and channel list captured from TM6900.
    At the moment I have to have two copies of Clarke Tech open and copy each favorite group, one channel at a time. What I would like to do is copy the fav channel (say Movies) across to the updated list.
    I've tried drag and drop to no avail.
    The reson I want to do this, is because I have deleted all the channels off Thor and rescanned them in, in doing so it deleted all the thor channels out of my Movie favorites and I then have to manually add them.
    Sorry for not explaining myself clearly.
    Cheers.
    Nov 2008
    north west uk
    Hi Benny,
    Cheers.
    i take it your trying to reset your favorites on the clarke-tech editor i have never tried this mate but i have a feeling that once youhave deleated and rescanned you have lost you favorites settings and i wonder if the only way is to manualy reset them all again. i dont use the editor i find it quicker to set all the chns in a good order on the technomate 6900 and then save the finished lists on my computer that how i know the clarke-tech chn list loads on the 6900 i sorted them on the tm because you can move groups of chns at a time, this is'nt possible on the clarke-tech chns only move one at a time
    Jan 2009
    Yes Benny thats the issue.
    I will continue to do it manually, Clarke Tech is certainly better than nothing.
    Thanks for your feedback once more.
