hello.....
hello.....
Hello m8
Your file fap off with chks OK
Pass in pm
Tried both files today, sadly none worked, car is still limited to 2000 rpm
And about dtc's ? make a log .. This car is two switchs solution.
Cheers
DTC tables were deleted in both files, only the single values were a bit different
I did try to apply changed bytes from both of the files, but still no power...
After that I found a 12x1 torque limiter, set at 2000rpm and after that it started going, but still not at maximum power.
So....afterall the car is working?
Sent from my LG-P970 using Tapatalk 2
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
It works, but not at full power, I think there are still some torque limiters for limp mode.
But it still is hacking, because car is in Limp mode, with torque limiter removed...
Mate if u turn off DPF by switch don't need to delete dtc table , or even change the limpmode torque limiter.
Works fine ... thanks
I had same issue - Vectra C... with KTS i made "replace DPF", after that with ECUSafe, done. 10 000 km without problem ... DPF is physically removed, all sensors are still there.
I am not claiming that this is the right solution, but for me in this case is obtained...
Hello Friend,
I have a problem with Zafira 1.9CDTI
"DTC tables were deleted in both files, only the single values were a bit different
I did try to apply changed bytes from both of the files, but still no power..."
Can I Please You to correct for me a 12x1 torque limiter?
Sorry for my poor English
Best Regard's
Edit: Can someone help???
Here is the file, with a modified 12x1 torque limiter.
Mind you - this is NOT a proper dpf off file and use it at your own descretion. This one should give you full power, but you should go to an expert for a proper file. Good luck
Thank's Taurius
I will test and report,
Best Regard's
