    DK Veteran pspmixer's Avatar
    Jun 2009
    liverpool(UK)
    Default try to flash tx replacement pcb
    trying to flash a tx replacemnet pcb board for xbox 360 slim
    i cant get drive to go into vendor mode
    jf log -~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    JungleFlasher 0.1.92 Beta (304)
    Session Started Sat Sep 15 12:20:56 2012
    This is a Wow 64 process running on 8 x 64 bit CPUs
    X360USB PRO detected, Version 0.18
    Found 1 I/O Ports.
    Found 3 Com Ports.
    Found 5 windows drives C: D: E: F: G:
    Found 2 CD/DVD drives E: G:
    Loading firmware file C:\Users\HP\Desktop\xbox 0225\Dummy.bin
    MD5 hash: 5934558548cd9b88c7da14b3f9e8b302
    Inquiry string found
    Identify string found
    Drive key @ 0xA030 4562783FF101283C8DE9FC06680B0555
    Firmware Osig: [PLDS DG-16D4S 0225]
    Firmware is: SlimKey Extract
    Auto-Loading firmware file C:\Users\HP\Desktop\JungleFlasher.0.1.92.Beta(304) \JungleFlasher v0.1.92 Beta (304)\firmware\LTPlus-0225-v3.0.bin
    MD5 hash: 1a38d3a2a6519339599fa1866642c513
    Genuine LT plus v3.0
    Drive key @ n/a FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    Firmware is: LT-Plus 3.0
    Spoofing Target
    DVD Key copied to target
    Key Sector copied from Source to Target
    Target is LT - ID strings not copied to Target
    Sending Vendor Intro to port 0x0000
    Status 0x80
    Re-sending Vendor Intro:
    Failed to open com port COM5
    Aborted by User!
    Found 3 Com Ports.
    Status 0x80
    Aborted by User!
    Status 0x80
    Device Intro failed!
    Status 0x80
    i have cki3i enabled so i dont have to power on and off xbox360usbpro all the time
    i have tried to put in vendor with this turned off and still doesnt do it
    any ideas thanks
    cunny's Avatar
    Jan 2009
    The Shoutbox
    There will be a lock switch on the pcb, put it to unlock
    Jun 2009
    liverpool(UK)
    already on wp 1
    i havnt touch that switch at all
    Sep 2012
    Default sweet
    sweet im glad you showed us how to do this thank you!
    cunny's Avatar
    Jan 2009
    The Shoutbox
    If you would just Google it or be bothered to read advice another thread then you would have this sorted.
    http://www.team-xecuter.com/forums/s...ad.php?t=67582
    Official guide to your product
    Jun 2009
    liverpool(UK)
    think i sorted it re installed drivers for x360 pro usb v2 and plugged board in, out and back in to it then did jf follow tut pages 213 onwards
    and it went to vendor mode
    followed tut to the letter and flashed it
    here is jf log- -- - - - - - - - - - -
    Session Started Wed Sep 05 11:38:23 2012
    New CD/DVD detected.
    Found drive C: - Hard Drive.
    Found drive D: - Hard Drive.
    Found drive E: - CD/DVD.
    Found drive F: - Hard Drive.
    Found drive G: - CD/DVD.
    Found drive H: - CD/DVD.
    No Hitachi drives were found!
    portio64.sys Driver not Installed
    Found 2 I/O Ports.
    Found 2 Com Ports.
    XECUTER X360USB PRO attached.
    Found drive H: - Invalid.
    XECUTER X360USB PRO removed.
    Drive is Slim Lite-On..
    Found 3 Com Ports.
    0000: 05 80 00 32 5B 00 00 00 - 50 4C 44 53 20 20 20 20 ...2[...PLDS
    0010: 44 47 2D 31 36 44 34 53 - 20 20 20 20 20 20 20 20 DG-16D4S
    0020: 30 32 32 35 00 00 00 00 - 00 00 00 00 00 00 00 00 0225............
    0030: 00 00 00 00 41 30 41 30 - 00 00 00 00 00 00 00 00 ....A0A0........
    0040: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    0050: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    0060: 44 37 31 34 43 47 30 32 - 38 39 31 30 30 30 34 33 D714CG0289100043
    0070: 51 20 20 20 Q
    Serial flash found with Status 0x72
    Sending Device ID request to port 0x0000
    Manufacturer ID: 0xC2
    Device ID: 0x11
    Flash Name: MXIC(MX25L2005)
    Flash Size: 262144 bytes
    Key: 4562783FF101283C8DE9FC06680B0555 is verified, Thanks C4eva
    Grabbing Key sector: ................
    Key Sector verified.
    Grabbing Serial info: ........
    Key data saved to C:\Users\HP\Desktop\xbox 0225\Key.bin
    0070: 51 20 20 20 Q
    Inquiry String saved to C:\Users\HP\Desktop\xbox 0225\Inquiry.bin
    0000: C0 85 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    0010: 00 00 00 00 37 44 34 31 - 47 43 32 30 39 38 30 31 ....7D41GC209801
    0020: 30 30 33 34 20 51 20 20 - 00 00 00 00 00 00 32 30 0034 Q ......20
    0030: 35 32 20 20 20 20 4C 50 - 53 44 20 20 20 20 47 44 52 LPSD GD
    0040: 31 2D 44 36 53 34 20 20 - 20 20 20 20 20 20 00 00 1-D6S4 ..
    0060: 00 00 00 0F 00 40 00 04 - 00 02 06 00 00 00 00 00 .....@..........
    0070: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    0080: 03 00 78 00 78 00 78 00 - 78 00 00 00 00 00 00 00 ..x.x.x.x.......
    0090: 00 00 F8 00 10 02 00 00 - 02 02 00 00 60 00 40 00 ............`.@.
    00A0: F8 00 10 02 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    00B0: 3F 20 00 00 ? ..
    Identify String saved to C:\Users\HP\Desktop\xbox 0225\Identify.bin
    0000: 44 37 31 34 43 47 30 32 - 38 39 31 30 30 30 34 33 D714CG0289100043
    0010: 51 20 20 20 FF FF FF FF - 30 46 31 31 31 31 33 39 Q ....0F111139
    0020: 31 36 38 30 31 35 58 58 - 41 30 FF FF 53 34 50 30 168015XXA0..S4P0
    0030: 37 30 39 30 30 30 30 30 - 31 31 39 30 32 33 00 00 70900000119023..
    0040: 00 00 00 00 00 00 00 00 - 00 00 00 00 41 30 FF FF ............A0..
    Serial String saved to C:\Users\HP\Desktop\xbox 0225\Serial.bin
    Hashing Drive: ................
    Dummy.bin file saved to Dummy.bin
    Loading firmware from buffer
    Key added to database
    Spoofing Target
    Session Started Sun Sep 16 20:25:45 2012
    Found 2 I/O Ports.
    Found 2 Com Ports.
    Found 2 Com Ports.
    Found 3 Com Ports.
    Found 2 Com Ports.
    Found 3 Com Ports.
    Status 0x80
    .................................................. ..XECUTER X360USB PRO removed.
    .......XECUTER X360USB PRO attached.
    .................................................. .....................XECUTER X360USB PRO removed.
    .................................................. ....................XECUTER X360USB PRO removed.
    Aborted by User!
    Found 3 Com Ports.
    Status 0x80
    Spi Status: 0x00
    Device ID: 0x11
    Spoofing Target
    Getting Status from port 0x0000
    SPi flash found with Status 0x72
    Sending Chip Erase to Port 0x0000
    Erasing:
    Writing target buffer to flash
    Writing Bank 0: ................
    Writing Bank 1: ................
    Writing Bank 2: ................
    Writing Bank 3: ................
    Flash Verification Test !
    Reading Bank 0: ................
    Reading Bank 1: ................
    Reading Bank 2: ................
    Reading Bank 3: ................
    Write verified OK !
    Sending Spi Lock request to Port 0x0000
    Spi Status: 0x8C
    Sending Spi UnLock request to Port 0x0000
    Aborted by User!
    Sending Vendor Outro to port 0x0000
    Key found in KeyDB at record (3 - xbox 0225)
    Key is: 4562783FF101283C8DE9FC06680B0555
    Key has been tested and verified, thanks C4eva !
