Results 1 to 8 of 8
Hybrid View
    Sep 2012
    Liverpool
    Default dish problems with openbox x3
    Hi I have a 100cm dish motor and a moonoblock lnb @ hotbird@13 degrees but I'm only getting 45% signal and a10% quality. But when I connect it to my old sly dish it works perfectly.and I've tried on a technomate and I was getting 77/80% signal but still only 10% quality still all new to this.
    DK Veteran nibblitz's Avatar
    May 2010
    Monoblock on a motorised dish? Thats not right... Sounds like you need to start from scratch with your dish installation...
    http://www.digital-kaos.co.uk/forums...ed-dish-42881/
    Sep 2012
    Liverpool
    Sorry my mistake I've got a universal one in my dish but I've also got a roadblock lab as a spare.
    May 2010
    Has your motorised dish ever worked correctly? Did you install it yourself?
    Sep 2012
    Liverpool
    I installed it myself but phoned a installer to check if it was ok and he said it was fine and I was on the right line but I'm just stuck
    May 2010
    How did you align it, how did you satisfy yourself its up correctly? What satellite did you align it to? Did you point it south then drive it to Thor 0.8w then tweak until you received signal/channels? Is the motor mounted on a dead on plumb level pole?
    Sep 2012
    Liverpool
    I installed it I assume it's right! as I phoned a installer to check the motor and dish alignment and he drove the motor to hotbird @13 degrees and the signal was on 77/80 degrees but only 10% quality, he said was on the right lines and to persiver with it,so I got a new receiver as someone here said me receiver was old technomate tm 5500 daci, so I got a openbox x3 and on that I'm only getting 45% signal and 10% quality I've rang someone to align it proper but I want to see if I can do it myself first.
    May 2010
    I think its best that you start from scratch and follow this guide to do it properly...
    If you phoned the installer, how could he check it was aligned properly if he wasnt there, its impossible...
    So yea, start from scratch... The most important thing is to get the motor and dish mounted on a sturdy pole (scaffold on T&K brackets is best) and it has to be perfectly plumb level, if its not you'll never get satellites across the skys arc... You then aim the motor and dish south, not towards 13e, not towards 28.2e, just south, 0 degreess... Then when youve done that you set your box to use USALS motor setting, add your local Lognitude & Lattitude into your box setting, add the Thor satellite position into your box, 0.8w, set your LNB settings universal, check usals is enabled, and then drive your motor to Thor... Then you tweak and fiddle the dish until you get Channels on Thor perfectly.. Once thats done you shouldnt need to touch the dish ever again, it should now drive to all other satellite locations without problem.. But you got to make sure your pole is Plumb level...
    The guide should see you through...
