Results 1 to 12 of 12
    DK Veteran manocao's Avatar
    Sep 2009
    Default Renault XR25PC all versions easy installer
    xr25pc 1.01-3.35 final easy installation
    1. install .net 4.0 and reboot:
    Microsoft .NET Framework 4 (Standalone Installer) - Microsoft Download Center - Download Details
    2. if after installing .net 4.0 your computer becomes slower when booting and network interfaces doesn?t appear after a while, run this in a console (cmd or make a .bat file with this):
    c:
    cd C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
    ngen update
    cd C:\Windows\Microsoft.NET\Framework\v4.0.30319
    ngen update
    pause
    if you are not sure if your system has become slower, you can do it anyway anytime, it will not harm your pc, it just reorganize-optimize .net 4.0, makes booting faster, fix things, doesnt make any bad
    then you can additionally run services.msc and disable these two services: .NET Runtime Optimization Service v2.0.50727_X86 and Microsoft .NET Framework NGEN v4.0.30319_X86
    3. here is "xr25pc -all versions- easy installer", install and follow the instructions (it is important that you copy-paste the fonts through 'control panel' > 'fonts'):
    ASK BY PRIVATE MESSAGE (check your inbox is not full)
    maybe it needs administrator rights to install
    it includes info for building ftdi interface
    .Net Framework 2.0 SP2 is required from versions 1.01 to 2.06
    .Net Framework 4.0 is required from version 2.09 onwards
    versions 1.01 to 2.00 are non voice-guided (faster)
    versions 2.01 onwards are voice-guided (slower)
    all thanks to R. Koster
    car-diagnose@live.nl
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following 2 Users Say Thank You to manocao For This Useful Post:
    diez78 (18th February, 2023), svallecilla (25th July, 2023)
  3. #2
    Sep 2009
    here is last version 3.35 with original installer by R. Koster car-diagnose@live.nl
    run install-first.bat, then setup.exe
    edit: deleted file
    of course, .net 4 framework must be installed in your system
    you don't know if it is already installed? run this or this
    __________________
    Sep 2009
    martinracing, your inbox is full, i cant give you link to download...
    edit: solved
    __________________
    206tc's Avatar
    Mar 2014
    Spain
    Hi all.
    I need this software, and all links are dead...
    Please, some function link or attachement?
    Thanks!!
  6. #5
    May 2017
    hello how are you, I want to know if you can help me, I need the XR25 software tool, I have a Renault R21 1993 year, the car dont start, I have a problem with the computer I asume or with a sensor
  7. #6
    Mar 2019
    Hi.
    Please, I need the XR25PC USB software to connect with my Clio II phase 1 with K4J 713 engine and automatic gearbox DP0.
    I need to view the Gearbox oil temperature to change it properly.
    I try to connect with a lot of diagnostic device and I canīt...
    Thank you very much in advance.
  8. #7
    May 2019
    Can you help me connect to a 12 pin Renault Twingo 95? I have problems.
  9. #8
    May 2019
    Quote Originally Posted by ronenfe View Post
    New project, full working, continuously updated, better interface, faster, easy to install:
    http://www.renault19.com.ar/descarga...llation-manual
    http://www.renault19.com.ar/descarga...ix-scanner-ecu
    https://www.ebay.com/itm/113696011319
  10. #9
    May 2019
    Quote Originally Posted by VictorR19 View Post
    Very nice, I've already found you on Facebook, but I have a Twingo with Magneti Marelli ECU, but I found out how to connect to it In Renault-bg forum. There is no need for a circuit. Only to connect the k line and l line to the Ftdi chip.
  11. #10
    Mar 2021
    Default XR25PC
    Quote Originally Posted by manocao View Post
    Hello, could you please send the latest version of this program?
  12. #11
    Jul 2021
    Hello!
    Did you get the latest version of XR25PC???
    I am looking for it myself, so if you got it, could you send it too me?
  13. #12
    Sep 2009
    Hello people, any way to get updated information???
    Software, USB connector etc, thank you.
