Results 1 to 3 of 3
    Jun 2009
    Banja Luka Ex Yugoslavia
    Default Corsa 2003 Easy tronic
    Hi to all.
    Does anyone manage to repair easytronic on this car, sometimes i have big F on display.
    Dtcs is Clutch actuator position sensor. But it is all inside, clutch is hydraulic it isn't like on smart, therefore i dont want to play with opening it.
    Staffs UK
    quote " therefore i dont want to play with opening it."
    Will you ever fix anything that way?
    It doesn't work anyway, what have you got to lose?
    Just in case you change your mind.....
    I think from the last one I looked at that if the clutch doesn't release ( input shaft continues to rotate with crank) the system tries to learn new release point and cant so it sets a position sensor fault.
    1 check fluid level and correct/bleed if required
    2 does the clutch release fully?
    3 with tools actuate and re-learn clutch positions and gear position adaptives.
    If you still cant pinpoint the fault check for faults on clutch and release bearing. Release clutch manually and actuate the gearchange disconnected from linkages.
    Jun 2009
    Ok, have not go so deep.
    I am no afraid of braking , i am afraid of loosing time with no money.
    But ok, i will try to do my homework.
