    germany
    Default SMART 451 Fortwo Coupe SAM Problems
    i have a smart sam 451 that was under water and now i need to reprog a used sam unit with the old data of the broken one. is there a way to have a virgin file for the sam 2011er MHD? Is there a possibility to read old SAM (not possible with DAS/Xentry) maybe with 912er CAS. Have anyone a picture of a open SAM to look where to put the pins ec. Thanks for help. Maybe some other solutions for me.. Thank you...
    Hi friend, is possible read the hold sam with UPA, for pics of the connection use NYO
    germany
    can you explain nyo?
    Oct 2011
    Portugal
    Forget you cant read this sam with upa it is secured,
    Can you send me the foto of your sam opened. Remove the black cover from fuse side and send me a foto. it is possible to read with x-prog or rosfar. I can help you if you need.
    germany
    Here is picture of the damaged SAM it is from a SMART 451 from 2011. Can you give me connecting picture for Rosfar?
    Jan 2011
    I used X-Prog M
    The connecting of one of my posts
