Results 1 to 3 of 3
Thread: TP.dbs File
    Default TP.dbs File
    my current tp.dbs file has the sky TP and im doing a scan for 23.5 Astra also but the scan only picks up the sky channels only.
    Correct me if im wrong but aint this the france satellite?
    How can i get the astra 23.5 channels without losing the sky ones also?
    I have the s11 using a 60cm dish monoblock and it was recently aligned (thursday)
    DK Veteran nibblitz's Avatar
    It sounds like to me:
    You have not set diseqc control on your box to use monoblock ports
    You have incorrectly assumed 23.5e is carrying French TV
    You have the wrong type of monoblock
    French TV is on 19.2e, there isnt a monoblock that will allow for 28.2e and 19.2e, you would need 2 seperate LNB's and a diseqc switch...
    Quote Originally Posted by nibblitz View Post
    You were right about the diseqc not set after a little play around i have them now, many thanks
