Results 1 to 14 of 14
    Bulgaria
    Default Sprinter 313CDi dpf off
    hi
    please help
    i need dpf off Sprinter 313cdi
    edc16cp31
    0281014345
    i try ECUsafe , volta decoder and some solution but
    not result
    please help
    best regards
    soundnavigator's Avatar
    Sep 2010
    The best DPF OFF solution in Sprinter is manually removed without erasing DTC and with emulated/removed DPF sensor.
    Best regards.
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
    Apr 2012
    hi. dpf off correct. all sensors emulates manually
  4. The Following User Says Thank You to Mehanic For This Useful Post:
    crafter2016 (24th June, 2017)
    Looking for DPF OFF (sensor emulating) solution for
    Sprinter EDC16CP31
    0281015052
    1037391212
    Solution is found.
    kazikk's Avatar
    Quote Originally Posted by lubomirblg View Post
    hi
    please help
    edc16cp31
    0281014345
    not result
    please help
    best regards
    Hi.
    Have you found proper solution for DPF off in Sprinter ?
    I have the same ecu and need to delete DPF,
    particulate filter have bin stolen
    A646 150 17 77
    0281014345
    1037386901
    HW31.06
    SW46.06
    Q01 ED6105 CR4.20
    kevfield's Avatar
    uk
    DPF off
    Thanks kev
  9. The Following User Says Thank You to kevfield For This Useful Post:
  10. #8
    How i mus"t emulate sensor in sprinter 313 2007y ?
  11. #9
    garagetech's Avatar
    Oct 2008
    please can you do dpf off for me thanks
  12. #10
    garagetech's Avatar
    Oct 2008
    Please help someone
  13. #11
    kevfield's Avatar
    uk
    Default Your file
    dpf switched off pass pm
    Thanks kev
  14. The Following User Says Thank You to kevfield For This Useful Post:
    garagetech (22nd January, 2014)
  15. #12
    garagetech's Avatar
    Oct 2008
    Hi thanks for helping , I've loaded file but van still smoking it might not be related to dpf . The van is giving bluish smoke at idle especially after fuelling when u rev .
    Had a look under hood and one injector seal is also leaking . Could this be the cause .Mechanic is going to have a look then will let u know if thats solved the problem. cheers
  16. #13
    likely to you have damaged the injectors need to be check
  17. #14
    Ukraine Sumy
    hello to all
    Can I get a password to the file
    WinOLS (MB Sprinter (dpf off) - 386901).rar
    thank you
