Results 1 to 5 of 5
    Nov 2008
    Default Total Noob - Why did I buy it
    I have a TM 5200D Super USB. All seems to be working fine and I am getting all of the Freesat channel (I believe). I am not thinking whether or not I am missing any channels I am suppose to get with this unit. If this unit get just the basic Freesat channels then why would you want this instead of getting a standard Freesat box from, say, ASDA. That might be cheaper.
    BTW; I am pointed toward 28.2 and have a mini dish.
    I am defo missing a point here somewhere.
    Thanks.
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    thats al you will get from that satellite, you need a motor to make the most of your box
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    Nov 2008
    Quote Originally Posted by Sadiq999uk View Post
    Thanks Sadiq. Would you be able to recommend a particular dish/motor and a dealer around London area or a web based seller?
    Thanks.
    Aug 2008
    var/tuxbox/plugins
    Look on wizardsatellite mate or southern satellite...any motor will do same with the dish.. You can buy whole systems without receivers altogether so that should be easy..
    Get a 80cm dish minimum but try a 90cm or 1m...
    Installation is difficult but possible even for newcomers..its patience which will get it all up..
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Jan 2009
    Colchester, Essex
    Default Same boat
    I'm pretty much in the same boat as yourself, but a plus of the 5200 is that you can record programs (I don't think your Asda Freesat can do that, but I may be wrong) and as has already been said, once you get your dish motorised there's a lot more to see. I'm taking a step at a time and seeing what's there before investing in motorisation.
