Results 1 to 8 of 8
Thread: MCU 68HC11E1
    Aug 2009
    Default MCU 68HC11E1
    HELLO
    I tray to reade this mcu of renault siemens ecu
    i tray it in upa and carprog but nothing can you help me
    the mask of the mcu is E28B
    THANK YOU
    Dec 2010
    Ro
    select upa HC11E9 OLD.its very easy.no cut or lift pin.
    Aug 2009
    I MAKE IT BUT NOTHING
    Dec 2010
    Ro
    try setting upa oscilator 6000.4000 .....khz.I tested this processor circuit reading.
    Aug 2009
    OK
    i reade it in carprog
    i lift txt-reset-mob and all ok
    thank youuuuuuu
    Aug 2009
    now only i make all ff the ecu is of renault megane 1.4 simens ecu
    this is the immo off or i make a mistake????
    Dec 2010
    Ro
    FF writes only the first line.i tested.
    Dec 2013
    hello friend can any one suggest 68hc711e9 could read by upa 1.3
