Results 1 to 15 of 29
    diagnoza_auto2000's Avatar
    Sibiu
    Default EZS/EIS test on bench
    Hello evryone
    I search some solutions for test keys on EZS/EIS on the bench on almost all Mercedes
    I have emulator for esl.
    Noimmo have some cable test for allmost all types but price is high for some cables only...
    There is another solution? But not to build myself cables..
    Default here is the solution for W203
    N73 is the EIS (Swich)
    N26 is the ESL (Steering Lock)
    just connect between them.
    Good Luck
    Sibiu
    I need somthing like this
    Equipment
    smayer's Avatar
    Jan 2012
    If you don't buy cables just do it yourself. Usualy just need connect 3 wires in EZS and use ESL emulator or old type ESL.
    You find all connection diagrams here, just use search button.
    If you need more details let me know.
    Default Hi
    Yes I did all also by my self, this is only solution.
    I have all the Esl on my stock, so I check every EZS.
    Sibiu
    But ESL emulator can be used for almost all EZS not need to have real esl,as i know.
    Maiby we can put here all the pictures with cables test and wirings
    Yes I know, but I prefer the Esl.
    Member starkey's Avatar
    Default ESL MERCEDES E210
    hello friends know to leave virjen eepron ESL
    E210 need to adapt EIS used
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by starkey View Post
    If you use the search button maybe you find here something like this----> http://www.digital-kaos.co.uk/forums...-203-a-293466/
    makura's Avatar
    makura's Avatar
    here you go.
  12. The Following 5 Users Say Thank You to makura For This Useful Post:
    ADEL.KSHLAF (11th October, 2016), chefdediag (8th May, 2017), deasturias (24th December, 2016), ecufix (18th April, 2016), houdiag (18th September, 2016)
  13. #12
    i_shot_the_sheriff's Avatar
    Nov 2008
    Can someone explain me what is going on with the ESLs?????
    I can't get a grasp of it with the support of noimmo!!!!!
    Is there a way to lock and unlock an ESL on the bench and test if it's good? I can't understand the whole "erasing", after that will it work with any EIS? Does it need adaption?
    Sorry for all these questions but i'm reallllyyy confused :/
  14. #13
    Sibiu
    I test ESL lock unlock with AVDI,and work great
  15. #14
    Nov 2008
    Mate, can you do it on bench?
    I got avdi too but no clue on it!
    For example, now i have a steering column at my shop from a w210! And i want to take the ESL out but it's locked! Is there a way to unlock it (i dont wanna drill it out ) ?
  16. #15
    makura's Avatar
    Quote Originally Posted by p0z3r View Post
    If you write virgin files to ESL it will work with any EIS until you personallise it (adapt it) to the car
