Results 1 to 5 of 5
    Oct 2011
    Default Cccam config switch v1.3 - help please!
    While trying to switch sea lions via the Cccam config switch the screen went green and now i cannot seem to select and highlight via a tick a different sea lion.
    When trying to select and tick the box of a different sea lion the spinning symbol appears on my open pli image. what can i do to get my Cccam info switch v1.3 to work and become active again?
    i would really appeciate you expert help please as a friend of mine who would definitely know all about this is not avaialble to ask.
    help would be very much appreciated.
    Sep 2012
    Default help
    re flash the box with image
    Oct 2011
    thanks whitey220783. is there no way i can just remove the cccam switch and then download again? just wanted to ask in case it is the faster option.
    Nov 2008
    check the enigma forums here, like vu and dreambox
    May 2008
    When switching CCcam config files occasionally enigma will delete the main CCcam.cfg (hence the green screen because it can no longer find the CCcam.cfg file). If you look in your /etc folder on your box you should see a number of CCcam config files probably named CCcam_01.cfg, CCcam_02.cfg etc (depending on the number of different sea lions you have). At the command prompt just type cp /etc/CCcam_01.cfg /etc/CCcam.cfg and you will be up and running again without have to re-flash.
    Hope this helps
    Chunkey
