Hybrid View
    Nov 2011
    South Belfast, Norn Iron
    Default Wrong system time
    I just upgraded to VIX 2.4 155 and since doing so the time on the box is wrong - it's an hour behind.
    It seems to be showing UTC even though I've set it to GMT which given the time of year should be BST or GMT+1 if you like.
    I tried changing the timezone to Amsterdam, but this goes to an hour ahead of the current UK time.
    I've mucked about, restarted Enigma2, restarted the box - everything I can think of. Even changed the time source from transponder to NTP.
    I'm baffled.
    Any ideas or anyone seen this before?
    Nov 2011
    I re-installed the image, but to no avail.
    The time is still wrong.
    Any ideas? It's doing my head in trying to sort it.
    Sep 2008
    menu-system-time settings-timezone-dublin,london
    try that if you are on a foreign sat i think times are mixed up.
    after box is flashed i think it gives you a quick setup guide like connections,locations and network.
    Nov 2011
    Quote Originally Posted by cactikid View Post
    Timezone already set and I'm on astra 28E only.
    Still an hour behind.
    I can find other people having the same problem, but no the solution.
    When I try to set it to a timezone one hour ahead, the time on the box jump 2 hours?????
    Nov 2011
    Did another re-install, but this time rather than restore my settings, I set it up from scratch.
    Seems to have done the trick.
    Right pain in the arse though.
    Sep 2008
    maybe older settings from older image may not be compatible with new vix?,glad your sorted for now.
