Results 1 to 11 of 11
    dave11674's Avatar
    Florida, UK
    Default pc startup problems slooooow
    hi guys
    just wondering if any1 can help me out here
    since day 1 my pc has bin a tad slow booting up
    now before i put a new hard drive in and do a fresh install id like to see if some of you tech guys can help me in anyway.
    i will enclose my ntbllog.txt file so u can see what drivers are failing to load etc
    i think this is the main problem that drivers are hanging and slowing the load up process down a bit.
    my pc spec is as follows
    Krypton Z68 650i Intel Core i7 2700K 3.50Ghz @ 4.60Ghz
    Asus P8Z68-V PRO Intel Z68 (Socket 1155) DDR3 Motherboard
    Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
    nvidia 295gtx
    main hard drive is a WD 300gb velociraptor 7200rpm
    thanks for any help with any tweaks you guys come up with.
    ive tried the usual noGUI options etc
    and stopped things running at startup
    but i think its deffo in teh drivers starting during boot up time and the windows logo on screen.
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    Mar 2011
    what OS are u using? did u install the motherboard drivers?
    is the gfx driver installed correctly? have u checked the temps of the cpu/gfx? is the ram installed correctly? might have 1 stick not in properly
    what power is the psu? has it enough power to power the board?
    check these things n let use know
    Nov 2008
    Norn Irn
    For what it's worth the only thing i can think off is to make sure your hard drive isnt running in PIO mode. This can make your PC crawl. Failing that make sure all your drivers are up to date.
    How To Fix Hard Drive Stuck In PIO Mode ? TechLogon Technology News | Tech News Help And Tutorials
    Nov 2008
    Norn Irn
    Also, while it's in my head have you tried booting in safe mode? Does it run any quicker. Finally, might be worth running check disk from command prompt in case you have corrupted files.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Thats allot of drivers to load and would be slowing it down.
    have you used msconfig to remove unwanted apps from boot?
    Another thing to consider is specs of hdd? WOuld it be worth looking into SSD to increase overall speeds?
    Never come accros any Velociraptor drives before so other than usual things to try
    dave11674's Avatar
    Florida, UK
    hi guys i opted for a new bigger drive (slower rpm) but 2.5tb over the 300gb veloc 7200rpm
    think i needed a new install anyways
    nice n fresh now
    thos some teethign probelms at mo
    ill get round them tho
    thanks for the tips ill keep them in mind for future ref
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Feb 2019
    try pc cleaner software, and also check task manager for what are the apps and background process running
    https://acmarket.download/
    Jan 2020
    Ukraine
    try to clean up with india-eraser your RAM
    Aug 2020
    Quote Originally Posted by Sherylbrock View Post
    try best free pc optimizer, and also check task manager for what are the apps and background process running
    appvn.io
    I agree wuth this opinion. I'll also use pc optimization software to boost up the speed of starting my PC.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Wink
    wisecare 365 pro is good and light
    Here if you need it ........................Paul
    woops post is 2 years old
    PAUL
    Jun 2022
    Make a error scan with hdtune check for bad sector and reading speed if 100< Very Good , 80> normal-Slow 70> Bad Change.
