Results 1 to 7 of 7
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    Default network setup help
    hi all can anyone please tell me what is the best why to set up this network in pic 1 this is my old set up all working well with no probs. what i would like to do is have everything giga setup and do a way with 2 the 10/100 switches
    in pic 2 is what iam looking to do with my network can it be done ??? and what is best why . (please rember 100% noob doing this sort of thing) thanks guys
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
    Jul 2008
    ok guys all i need to do now is get the dlink working downstairs now everythink else is working
    cheers
    Jul 2008
    ok all done and all working
    May 2018
    En su día le hice esta misma instalación a un amigo y le funcionó varios años.
    Jun 2018
    Virgin Islands
    Can you post a screen shot of the network setup in the DVR so I can double check it? Shane
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Glad its goimng. Time on here very very limited.
    couple pointers though, Let main router handle DCHP requests so you dont end up with IP Conflicts
    2nd. You might have to put ethernet lead into LAN instead of WAN depends on router.
    I use a very similar setup and it works really well
    Jun 2022
    Quote Originally Posted by MichaelThugs View Post
    I want that too
