Results 1 to 10 of 10
    May 2011
    Default Audi A1 Long Coding for Sat Nav
    hello, i've got an audi a1 here and they want the sat nav enabled on it, it has all the loom, two sd card slots,ipod connection in glove box all the common things to check for, they also have the memory card. i have read that it needs long coding in but everywhere i read there seems to be a conflict in exactly what codes to use, so could anyone tell me in which menu on vcds and what number/s to add on to enable it.
    Thank you
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    Quote Originally Posted by leemcochran View Post
    Thank you
    is it original VAG Navi system , then can do it,
    is it not , then is not posible
    May 2011
    Yes it's an original vag stereo
    May 2011
    anyone able to help atall? i just need to know what numbers to add onto the long coding for a deffinate
    Jan 2009
    Sweden
    May 2011
    thank you for the links but none of them really help with what im looking for, i have searched the rosstech website aswell, i just need to know what number to add onto the long coding for an A1 system to work.
    Jan 2009
    Sweden
    do you have original VCDS and which version?
    Jun 2009
    if it's a new car 2009 and up, coding can only be done online.
    May 2011
    yeah its a 2011 car, so it can only be done online by an official dealer end of?
    Jun 2009
    yes mate, only official dealer, i had same prob with an AUDI A3 2011, with ABS coding, and only dealer was the solution
