Page 12 of 24 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 346
  1. #166
    Member theyel2001's Avatar
    Sep 2008
    Nottingham
    installed and working fine. but how do i delete sgtflipflop channels please ???
    thank you
  2. #167
    merseyside
    Quote Originally Posted by theyel2001 View Post
    thank you
    Press down arrow (while not in any menu) then blue for favs , select which group you wanna delete then menu, select delete from pop up box
  3. The Following User Says Thank You to southpaw For This Useful Post:
    theyel2001 (16th April, 2013)
  4. #168
    Apr 2013
    Hi, Does anybody know what the oldest version of Blackhole this will work on folks, thanks in advance!!
  5. #169
    Dec 2012
    How to make the latest update for this plugin on my DM 8000?
  6. #170
    Aug 2012
    hi all, ive installed it on my amiko 8900 but when ever I run it, with or without scripts I get error messages and nothing happens to my channels. cant figure out why?
  7. #171
    Nov 2011
    South Belfast, Norn Iron
    Quote Originally Posted by wroenaldinho View Post
    What are the error messages?
    Have you permissions on the necessary files set to 755?
  8. #172
    Aug 2012
    Quote Originally Posted by DMBoot View Post
    sh: line 279: ./autobouquets: permission denied
    sed; /tmp/bouquets.tv: no such file or directory
    sed; /tmp/bouquets.radio: no such file or directory
    reading network table
    /usr/lib/enigma2/python/plugins/extensions/autobouquets/autobouquets_e2.
    sh: line 316: .autolamedb: permission denied
    process NIT transponders services
    updating service
    cat: cant open 'tmp/nit_sorted.txt': no such file or directory
    cat: cant open 'tmp/lamedb_services.txt': no such file or directory
    updating bouquets
    then goes back to start screen with tickboxes
  9. #173
    Aug 2012
    I set dvbsnoop to 755 and also .sh file and ftp'd them
  10. #174
    Nov 2011
    /usr/lib/enigma2/python/Plugins/Extensions/AutoBouquets
    autobouquets
    autobouquets_e2.sh
    autolamedb
    set to 755
  11. #175
    Aug 2012
    autobouquets
    autobouquets_e2.sh
    autolamedb
    set to 755
    it worked thanks. I realised I missed 2 files. cheers
  12. #176
    Top Poster + damiensk's Avatar
    manchester
    got this running on a blakhole 1.74 on a duo, and everything is running fine, great addon
  13. #177
    manchester
    further update and question, ive got it running ok and updates fine, but i alter each bouqet to my taste, but after an update it all goes back to before my changes,
    so how do i go about using the autobouquets, but leaving my prefrences within each bouquet,
  14. #178
    digicon's Avatar
    Quote Originally Posted by damiensk View Post
    You would have to change this at code level as it is preconfigured when installed, I am sure there must be a way to do it but i am not too sure how.
  15. #179
    May 2008
    if you want to arrange your channels to you own taste, then you are probably better using the later slower script version enigma2-plugin-extensions-autobouquets-e2_201210091615_all.rar in post #12 rather than the faster latest version enigma2-plugin-extensions-autobouquets-e2_201303010205_mipsel
    this still has the old style custom.txt user config file and coding that reads/writes channels in a 101-999 order as detected in the custom.txt file.
    the later plugin versions changed to simply use this custom.txt file to swap channels with each other. nobody gave feedback that they used the custom.txt file to create there own custom channel order so the coding was changed in later versions to use this custom.txt file as a channel swap file instead of a 101-999 custom channel order file.
  16. The Following User Says Thank You to LraiZer For This Useful Post:
    damiensk (25th June, 2013)
  17. #180
    Jan 2009
    After setting up my clone 800 successfully tried doing the same with my original dream 8000 box running dream elite 4 and cant get this to work I get the following errors when ran
    root@dm8000:/usr/lib/enigma2/python/Plugins/Extensions/AutoBouquets# ./autobouquets_e2.sh
    Mon May 20 20:22:21 IST 2013
    Settings:
    [1] Data is 10 05, Region is 01
    [2] Data is 10 08, Region is 21
    HD First is false, Numbered is true
    Updated is true, Placeholder is false
    Parental is false, Default is true
    Custom is false, FTA Only is false
    reading Service Description Table
    Error(145): read (PID 0x0011): Connection timed out
    reading Bouquet Association Table
    parsing Service Description Table
    parsing Bouquet Association Table 01
    parsing Bouquet Association Table 21
    merging Bouquet Association Table
    merging BAT Tables and SDT Tables
    writing Bouquets and Services
    reading Network Information Table
    and then hangs!
    The files have all been 755 and i have performed a channel scan prior to installing but dont seem to be having any luck... Can anyone offer some advice here thanks
    Checking my running processes I see
    11742 pts/0 T 0:00 /bin/sh ./autobouquets_e2.sh
    11827 pts/0 T 0:00 dvbsnoop -n 5 -nph 0x10
    11828 pts/0 T 0:00 sed -n /\(^ Transport_stream_ID:\|^ Frequency:\|^ Polarisation:\|^ Kind:\|^ Roll
    11829 pts/0 T 0:00 sed s/^[ \t]*//
