hi, this plugin works great, anyway to get bbc one hd , bbc 2 hd , itv hd , channel 4hd and channel 5 hd in the entertainment list ? i can see it in all list and HD bouquet , thanks
From another forum ...
here is latest AutoBouquets E2 version dated 2013/08/25 17:00
archive contains sources, binaries, installers for mipsel, mips32el, sh4 STB's.
25-08-2013
fixed reading intermittent missing channels in bat tables,
added crc and more error checking to stop missing channels.
s
guli (3rd November, 2013), southpaw (5th September, 2013), The Mentalist (21st September, 2013)
I'm currently running the 1/3/13 version of this plugin on an sh4 box. How do I upgrade it to this new version?
I tried the ipk and it says it's installed but it doesn't showup in the plugin list. Can I just ftp the usr folder across like I did for the version i'm currently running, and just allow it to overwrite any files with the same name? Do I need to change any of the attributes of any files?
How does one know which version of box. for instance mipsel or mips32el
Still trying to figure out how to update to newest version, have also tried opkg install -force-overwrite /tmp/*.ipk after using DCC to ftp the file to /tmp, but got this error
"Installing enigma2-plugin-extensions-autobouquets-e2 (201308251700) to root... Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enig
a2-plugin-extensions-autobouquets-e2:
* enigma2 *
* opkg_install_cmd: Cannot install package enigma2-plugin-extensions-autobouqu
ts-e2. "
Any help would be much appreciated.
i getting the same two m8
* enigma2 *
ts-e2. "
some images for sh4 boxes cant even detect that they are running enigma2, so the installer for sh4 will fail as engima2 is a named dependency in the sh4 installer.Originally Posted by seventhson
also if your sh4 image is the OpenPLI HYBRID by polish coders team, they have deliberately coded their boot scripts to delete autobouquets plugin at startup.
first remove the crashlogs from your hdd before you install these HYBRID images on sh4 box, so that plugins are not detected in any crashlogs and automatically removed!
once HYBRID image is installed you can delete the reference code for a plugin from the reportGS cron job so that it does not get removed if a user installs a backup image and they have older crashlogs from previous unstable plugin versions still on their hdd. EDIT FILE: /jzk/cron/post_E2/reportGS
also you need to remove the AutoBouquets reference from the HYBRID image blacklist. EDIT FILE: \jzk\etc\init.d/blacklist and delete the AutoBouquets reference.
this ipk installer will now work on polish HYBRID images for sh4 as the engima2 dependency has been removed.
Last edited by LraiZer; 26th September, 2013 at 11:24 PM. Reason: removed 'crappy' reference as the image is actually not bad apart from the creator banning AutoBouquets plugin for no reason!
guli (3rd November, 2013), PaphosAL (27th September, 2013), ronan collins (29th September, 2013), seventhson (27th September, 2013)
Thanks for the reply. I'm using the HDMU image, so didn't have the two files to edit. However, I deleted the few crashlogs on the hdd, ftp'd the ipk in your post to /tmp and then tried the telnet install from before and it installed straight away!
Thanks again for an awesome plugin!
I Have to say LraiZer the new autobouqets setup is Fantastic and i love it Keep up the good work
Why is Auto bouquet missing Sky Sports News?
thanks for the updated version, works perfect and quick, even typing in channel number takes you direct to channel and that section, what a plugin !
so when this is installed i can then disable epg downloader? providers etc or opentv
Is there a way to remove the empty channels numbers from the bouquets?
